SL/R230: Need help finding ABC pump replacement guide
Old Aug 23, 2018 | 12:13 PM
aeb28's Avatar
SL600, S550, GLS450
I have had a small/slow leak coming from the ABC pump for a while now. ABC light came on the other day, went ahead an did a ABC flush fluid replacement with 10 liters of pentosin. A couple weeks later, fluid is dirty/smells burnt already.
Now I am getting ABC Warining light coming on with ABC low pressure codes coming up. Pump is putting out 150-180 BAR for a few minutes, then it seems to just shut off and pressure drops. After I reset, pump may or may not bring pressure back up. After some research it sounds it might be a sticking valve on the pump. Sounds like it is time to change pump? I appreciate any advice.
A while back I came across a step by step with pictures, tools, parts and materials to remove and replace the ABC/power steering pump. I cant seem to find it again. Does anyone know where to find it?
EDIT: Found it! Would still appreciate any advice/input before I get started.
https://mbworld.org/forums/sl-class-r230/614186-diy-remove-install-abc-pump.html
2004 SL600 5.5L v12, ordered with SL55 package from factory (not sure if that will make a difference).
Thank you.
Old Aug 25, 2018 | 02:39 PM
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
https://www.partsgeek.com/catalog/20.../radiator.html
Thank you.
Where is the tutorial?
Old Aug 31, 2018 | 05:46 PM
aeb28's Avatar
SL600, S550, GLS450
Sorry pasted wrong link. Here it is.
https://mbworld.org/forums/sl-class-...-abc-pump.html
Old Sep 3, 2018 | 03:04 PM
CLK3202001's Avatar
2012 E350 Blue Tech Coup & Mercedes Benz,2004 SL500,& 2006 Harley FLHTCUI 2006 Ford E150
remove ABC pump
I used DIY, utube, video, remove belt, pulley then have access to 3 bolts hold pump.
I replaced the ABC system with a kit from StrutMaster.com
Good luck, the hoses are quite difficult, patience,patience,
Old Oct 11, 2018 | 02:10 PM
guydurrett's Avatar
2004 SL55 AMG
Hi, can you confirm the StrutMaster.com address? It comes up with a domain for sale listing.
Are there OEM replacements worth looking into other then Factory? I may have to replace my ABC shortly. Thanks!
Old Oct 14, 2018 | 06:06 PM
ryanorielly's Avatar
2007 SL550
Just ordered my strutmaster kit. Talk to Tammy, she is really helpful and easy to get in touch with. Installed a power steering pump from a s500 yesterday . Forgot to order the reservoir so that will be this weeks project.
