SL/R230: 2006 SL500 Heater Control Valve Location
Old Sep 10, 2018 | 11:19 AM
Tom Diab's Avatar
2006 SL 500
Hello,
I have no heat and so I will first change my heater control valve. But I wonder if there is a thread for my model or can someone tell me where the valve is located. I have searched for threads but I cannot find one about replacing this in my car. Any help?
Thank you
Old Sep 10, 2018 | 02:15 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
See if this helps:
http://benzbits.com/r230/HeatExchangerValve.pdf
Old Oct 27, 2023 | 04:02 PM
cjhazard's Avatar
SL500, G500, Tesla Roadster, Tesla Model 3 Performance, Willys CJ2A, Toyota Tacoma
Did this repair work for you? I'm having a similar problem - no heat, but the blowers and control unit seems to working fine.
Old Oct 30, 2023 | 12:42 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
That PDF form Rudeney tells you where it is..! Right under the windshield wipers bay. Need to remove the windshield wipers, they surely are stuck in the splines...! Need an small extractor tool. Then the rest is removing the plastic cover underneath, and you will be able to see the valve...would need extra long nose pliers to disconnect the hoses....! With the right tools...1 hour job and some hand scratches..!
