SL/R230: Alarm
Old Sep 28, 2018 | 11:03 AM
cheweedog's Avatar
SL500 2004
Alarm
Alarm goes off when I lock door What is the problem
Old Sep 28, 2018 | 01:10 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I could be a bad ATA siren. They have a built-in battery that will eventually die and leak on the circuitry, causing odd problems and even total failure. Another possibility is that the tow sensor has failed. To check if it's the tow sensor, disable that before exiting and locking the car. if you want to inspect the ATA siren, it's located under the fender shroud behind the left front wheel.
