SL/R230: 30 minute clock setting
Old Nov 10, 2018 | 05:11 PM
joebaehr's Avatar
Veteran: Navy
2005 SL500
Having trouble with latest time shift in the 2005 SL500. Country and timezone set fine, hours and AM/PM adjust as desired, but minutes are off by 8 (late) and up/down arrows only adjust by 30 minutes...tried reset in the COMMAND menu to no effect, but cannot find disconnect COMMAND SAT that is also mentioned in the manual in the actual COMMAND options. Any help appreciated! Internet advice so far was to disconnect battery,
Old Nov 13, 2018 | 01:11 PM
chad500sl's Avatar
2017 SL550 (R231), 2021 E350 (W213)
In my 2005 SL, I use the settings menu in the instrument cluster.
1) Enter settings and select time
2) Disable syncing with the head unit
3) Adjust time as necessary
4) Optionally re-enable syncing with the head unit. I normally leave this off
Old Nov 13, 2018 | 04:08 PM
John D Carr's Avatar
2003 SL 500
Same issue? Going back to 1999
Originally Posted by joebaehr
Having trouble with latest time shift in the 2005 SL500. Country and timezone set fine, hours and AM/PM adjust as desired, but minutes are off by 8 (late) .....
Funny. New here but I recently had the same issue. Originally year set as 1999 so I changed it 2018. Problem arose when setting the time, change year back to 1999 and no more problem setting the time. Funny coincidence I don't know.
Once I sort out my ABC issues, I'm going to add a double DIN touch screen stereo.
Proud owner of a Mercedes Whoopty?
Old Nov 13, 2018 | 07:51 PM
joebaehr's Avatar
Veteran: Navy
2005 SL500
Using instrument settings menu worked great, so much for doing everything in COMMAND screen,
Thanks chad500sl
Old Dec 4, 2018 | 03:17 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
[QUOTE=joebaehr;7600029]Having trouble with latest time shift in the 2005 SL500. Country and timezone set fine, hours and AM/PM adjust as desired, but minutes are off by 8 (late) and up/down arrows only adjust by 30 minutes...
That is normal. Car is waiting for satellite connection , which should effectively adjust your clock with frightening precision.
Old May 25, 2019 | 08:24 PM
myfirstmbenz's Avatar
2005 SL500
I'll try the instrument cluster, too. I always thought the satellite method would auto-adjust it. Any way to initiate that?
Old May 27, 2019 | 11:14 AM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
See this thread of mine a couple of months back. https://mbworld.org/forums/sl-class-...set-clock.html
I ended up desynchronizing the clock from the head unit and set it manually. It appears that there is no fix.
Old May 27, 2019 | 02:27 PM
Why our clocks are off several minutes: read it In the thread mentioned just above, post #7. We are doomed.
