SL/R230: Restoration to original suspension SL350
Old Dec 26, 2018 | 02:52 PM
Pspsps's Avatar
Mercedes SL 350
Hello,
as it seems that previous owner lowered the suspension in my SL I would like to bring it back to the original height. I'm sure that front is lowered approximate 30mm but I'm not sure about the rear suspension. I would like to ask You to check the distance in another SL 350 without hydraulic suspension. I would like to ask for a distance between floor and fender . Thanks.
Old Dec 27, 2018 | 12:35 PM
Po Annerfeldt's Avatar
Mercedes SL350 R230
I have a 350 and i have 69 cm, front and rear...
Old Dec 27, 2018 | 12:52 PM
Pspsps's Avatar
Mercedes SL 350
Many thanks. It seems that only front coil spring has been replaced in my car. Rear is 68-69cm. I will replace front ones and I will see what to do with rear.
Old Dec 27, 2018 | 12:55 PM
Mercedes SL350 R230
Old Jan 7, 2019 | 01:32 PM
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
Just wonder if the tires are hitting the fenders since you will go back to original height?
Old Jan 7, 2019 | 03:59 PM
Pspsps's Avatar
Mercedes SL 350
I have replaced front springs to original ones. Now the car body is 20mm higher so there is a bigger gap between wheel and fender.
Old Jan 7, 2019 | 04:02 PM
Pspsps's Avatar
Mercedes SL 350
There was no collision between wheel and fender before with low sport springs.
