SL/R230: LOCKED OUT
i cannot unlock it shows flashing when you lock or unlock but it doesn't make that unlocking sound any more
any idea what to do now?
moretech
moretech
when i unlock the car or when i am in the car i hear all these clicks or nuts being tightened ... i mean are you supposed to hear all these things move and for how long?
do you think it's a line that needs replacing or is it the whole pump. i called my local mercedes dealership and they quoted $3000 with labor but they urged me to do diagnostics first. item#2308200648 or A2308000648?
If if you continue to hear the thumps in the trunk for more than about 15-20 seconds you have an air leak. You seem to have already found the fuse. Remove it and follow the sticky on the trunk close repair mentioned above. Once you have the mechanism out inspect it and you will most likely see a crack in the plastic that is the cause of the leak. Easy fix.
Another spot to check for a leak leak is the air bladders in the seats. To check, get in the car with everything turned off in a quiet area. Listen closely in the lumbar and front of the seats for a hiss. Both of mine leaked. I believe due to pressure I placed on them when repairing the front roof lock cylinder.
Good luck.
As for the noises, one that you might hear is the SBC (Sensatronic Brake System) charging. It will sound like a motor or air compressor under the hood running briefly. This can happen at any time when the car is "awakened", which happens when you open a door. This is totally unrelated to the PSE (pneumatic) system used by the trunk latch, door locks, interior compartment locks and the seat lumbar adjustments. This pump is located in the trunk, inside a sound-deadening box. You will hear some clicking noises from the latch when you open and close the trunk, and you may hear a very faint sound of the PSE pump operating, and even some "swooshing" sounds of it pumping air. These are all normal sounds.
Note that if you hear air blowing sounds for more than a second or two after opening or closing the trunk, then you have a leak in the latch (which is very common) and should be fixed.
Good luck.
great point there. for sometime the seat lumbar support hasn't been working. so ? it is the PSE pump? or one of those yellow lines that needs to be replaced?
typically it is the seam of the air bladder that is leaking. Without replacing, the best and quickest fix is to cut the air supply line to the seat and plug it.
Thanks,
Tom
but i do know for convertibility i need the lock to work?? what's the solution here though. replace the vacuum pump?
it was the pulsation regulator. the THIEVES lying scum CKSUCKERS at mercedes told me it was the ABC pump and the valves that need to replace without even giving a **** to investigate what was really wrong or what happened they wanted "$5000 to start". ABC pump was fine the pressure valves were fine too.
bought the fender from ebay happened to be the close color cause my car is pearl black as opposed to just black and yeah.
