SL/R230: Here we go...
Found it. The high pressure line that goes to T block under the middle of the car.... GRRRRR
Can it be cut somewhere the metal section and a compression or flare fitting installed? I have no idea how this line would be removed and installed in one piece. It's pinned between the heat shield and frame as it goes over the front suspension, then back down through the transmission tunnel where it end with the T block.
