SL/R230: BIG Red Battery warning
2008 SL550
No, because another option exists whereby the software runs on an external drive in a "Virtual Machine". All else being equal, this configuration is markedly slower. But I suppose it would work quite satisfactorily with that jazzy Thinkpad X220. I'd go for it and choose the "usb" color option from the posting I cited.
MBworld Guru
Not to throw a wrench into things here, but I run my SDS on a Dell D630 that has 8gb of ram, Window 8.1 and a 256GB SSD. It then runs under VMWare using Windows XP as its O/S. It's very fast. In fact, the laptop in general is as fast as any mid range modern laptop.
I also run a copy of it under VMWare on my Lenovo Core i5 Windows 10 laptop just to access WIS, EPC and other technical resources while on the forums. My advice, once you get the setup, make a copy of that VMDK file somewhere in case you "hose" it on the laptop.
Back to your battery warning issue...my car does this every now and again. What I have discovered is that there is sometimes a delay as to when voltage comes up after starting the engine. I don't know if this is the voltage regulator or the BCM at fault. I have a plug-in cigarette lighter voltmeter that I use sometimes and will see it hanging around 11.9v until about 30-45 seconds after starting, then it jumps up tot 14v. Sometimes it take more like a minute to jump to 14v, and that's when I get the battery icon. But it goes away on restart. And this only happens maybe once every few months.
MBworld Guru
Not on mine - I'd hear it. I think it might be the aftermarket alternator I have. I really need to get an OE voltage regulator and put the OE alternator back on the car...someday.
I had the Battery red warning appear on my dash after I charged both of my batteries. It turns out you must connect the main battery (under the hood) first before you connect the accessory battery. If you don't do it in that order, you will have that and several other problems. Any time you disconnect the accessory battery, make sure, as soon as you start the engine, you turn the steering wheel all the way to the left, then all the way to the right, and roll down all four windows, then roll them up again. (and you also have to reset the clock)
Brian A.
Brian A.
2008 SL550
Brian A.
Brian A.
Mine is still displayed, everything is working as they should, I can leave the car for a week and it will start with one press of the button. I did not disconnect any battery, all I did was connect two trickle chargers to both batteries at the same time, but the rear battery was beyond salvage, as soon as I unplugged the trickle chargers, then the light came on. And the light is different, it doesn’t have the “visit workshop” like others have.
#32
Mercedes says that the batteries should be disconnected before charging them. Try disconnecting the accessory battery, then the main battery.
! Always connect the batteries in the order described below. Otherwise the vehicle’s electronics can be damaged.
Turn off all electrical items, heater, radio, lights etc. Connect the main battery, then connect the accessory battery. Not doing this had me running in circles for a while, and it took a couple of tries for the red Battery warning to go away. This assumes that both batteries are in good condition.Brian A.
#33
2008 SL550
�� Turn off all electrical items, heater, radio, lights etc. Connect the main battery, then connect the accessory battery. Not doing this had me running in circles for a while, and it took a couple of tries for the red Battery warning to go away. This assumes that both batteries are in good condition.Brian A.
#34
Yeah, I'd try for the do over, disconnect then reconnect it the proper order. It fixed it for me.
I'm wondering if charging the accessory battery before when it was connected is a reason I keep getting the "accessories not available" warning now, maybe it burned something out. I use trickle chargers on my motorcycles all the time (both have solid state batteries) but a charger is a lot more juice. Did you ever try to charge your batteries?
Brian A.
Brian A.
#35
2008 SL550
Brian A.
Brian A.
#36
I check fuse 71, it was good. However, the slot for fuse 72 was empty. The purpose of that fuse is listed as:
"Valid for code (424) Sequentronic automated manual transmission (SEQ):
Automated manual transmission control unit (N15/6)"I don't know if there never was a fuse there, it fell out or was taken out by a previous owner. I guess I should go buy a selection of spare fuses.Brian A.
#39
I took my SL to the shop today, they tested the charging system and said its ok, but the battery is bad.
I thought "Heck with the cost, I'm going to replace it with a Mercedes Battery" I called the local dealer, they have none in stock and they are on a 2 month backorder.
crap.
I guess I'll research Mercedes battery alternates.
Brian A.
crap.
Brian A.
#40
2008 SL550
crap.
Brian A.
crap.
Brian A.
The alternates are Just as good... I got my Auxiliary battery at Autozone and my Starter battery at Advance Auto. I haven’t had any issues with them.
#41
MBworld Guru
They last two genuine MBZ batteries I've had have lasted barely 3 years. I have been very happy with the Advance Auto batteries and have had several last longer than 4 years. I think the days of the good ol' MBZ batteries that lasted 7 years are long gone.
#43
Using a trickle charger would be a bit of a hassle for me. It's my daily driver and, for now, must be parked in my driveway. Another problem is I often work long hours several days in a row. I'll go to work before sunrise, go home ofter sunset and the drive is usually 10-15 minutes, not enough time to recharge the battery running the headlights and heater or AC running full blast. After a 12-16 hour day I'm too tired/lazy to want to deal with the trickle charger. I do use them on my motorcycle batteries, and they both have Lithium ones.
I just ordered an Optima Yellow Top H6 from Big Time Battery for $269. More expensive than the Autocraft but it has better specs and good reviews.
Brian A.
Brian A.
#45
2008 SL550
UPDATE!
I have successfully cleared the Big Red Battery warning sign with.... iCarSoft MB II, just received it from amazon and cleared it in 5 minutes. I’m still getting Star Diagnostics but for now, I’m happy. I’ll be visiting the dealership tomorrow for an alignment, which is looking like only them can do it. They already suggested earlier that I probably have to replace a control unit for the battery 😀
#46
2008 SL550
Went to the dealership this morning for an alignment, unfortunately it wasn’t successful, they said that they did all they could but I’ll have to do other repairs first. They suggested that I replace the Lower Control Arms, Bushings, Bolt kits + Ride height calibration: $3.050 plus TAX. Where can I buy these parts as a set?
#50
Optima H6 9048-148 800CCA
I bought it from Big Time Battery for $269.99https://www.bigtimebattery.com/store...edes-Benz.html
-BrianA.
