SL/R230: Upgraded radio 2007 SL 550
Old Mar 1, 2019 | 10:22 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
This is a dispute that will never be settled. We subscribed to a fabled series 'Grand Musicians' in the Amsterdam Concertgebouw. Both the venue and the orchestra are known the world over as top of the bill. Ten great concerts, good seats. Now and then I closed my eyes and wondered if this was undisputedly better than the CD at home. Ambiance: yes. Quality of sound: not always. No editing in a superb mixing studio, done by a top producer. Better or worse? Just different, that's what it was. Nothing beats a life performance, but canned music does have it's advantages. I would expect a car with a tweaked hifi set to be almost as ideal as it gets: everything can be tweaked, as opposed to a living room. Every argument bobterry proposes is totally sympathetic to me, but my stock NTG1 audio set up is dull. Those who critized it at it's launch were right from the beginning. Solid, reliable, but dull.
Old Mar 1, 2019 | 05:29 PM
Leej's Avatar
2008 SL550 R230, 2004 E320 W211
@jps33, Thanks for sharing about your install. I have been wanting to change my radio for some time and have been debating over a Chinese Android head unit or some other name brand aftermarket head unit. I was looking at the Seicane (Chinese) radios here:
https://www.seicane.com/car-dvd-play...th-srd-s018817
This looks to be the same radio that you installed, maybe just under another brand.
However, I contacted Seicane to confirm that it would fit my 2008 SL550, and they asked me to send to send pictures of my factory radio and center console, which I did. They responded that it would NOT fit because I do not have the trim around the radio? See pic below:
Apparently on mine, there is no trim between the radio and the leather on the console (compared to the picture originally posted by jps33; I presume this trim hides the edge tabs on the Chinese head unit?)
Does anyone else have experience with this or has installed a different head unit with a center console like mine?
I understand and appreciate the points made by bobterry99, and I don't disagree with his wisdom. But, a car radio is no longer just a radio, and everyone values the various functions and aspects within a radio head unit with different priorities (sound quality vs. GPS navigation vs. smart phone integration vs. auxiliary source capabilities vs. ease of installation vs. price vs. controls/interface vs. name brand vs. cosmetic appearance... and the list goes on and on...).
The AVIN MOST Fiber interface suggested by bobterry99 looks to be a great option for going with some other name brand aftermarket radio. I suspect it would work with Bose, even though it says it will only work with Harman Kardon. Seicane has one as well here, and it says it works with either Bose or Harman Kardon. I believe you would lose steering wheel controls, but maybe there are other options to interface with steering wheel controls.
Lee
Old Mar 1, 2019 | 05:55 PM
MB sacrificed the elegant trim around the head unit to a unit with a bigger screen. I think this was in 2005. The Chinese units seem to focus on the older configuration.
Old Mar 1, 2019 | 07:42 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Technically inferior audio systems add distortions and colorations which can be pleasing to some listeners. Consequently, with some music great audio systems can sound comparatively dull.
I'm reminded of a dozen years ago when I purchased Infinity's smaller version of its IRS (pictured in my prior post), and a friend found their sound underwhelming and inferior to his far less expensive Bose 601s. And that leads to a point mentioned elsewhere in this thread: audio is highly subjective. What sounds wonderful to one person can sound dreadful to another. For this reason it's prudent to take anyone's opinion of sound quality with not a grain but instead a kilogram of salt.
I would expect a car with a tweaked hifi set to be almost as ideal as it gets: everything can be tweaked...
And since the R230's stock sound is tweaked with custom equalisation and digital signal processing, I truly wonder how it can be significantly improved without making modifications to the interior of the car which are of questionable taste.
Old Mar 2, 2019 | 11:25 PM
Duckmoore's Avatar
2007 SL 550
Thanks so much for that advice!
Old Mar 3, 2019 | 01:34 PM
Austinsec's Avatar
Sl55 2003
Just fyi this radio has may issues I bought it for a sl55 2003 . Reception awful, every time you turn car on you need to wait for reboot , no fast start like ,alpine,kenwood.
bluetooth hit or miss. looks great , I am having too ship mine back to china for replacement at a cost of 90.00 after buying it for full price.
So I would look on the forum about reviews for this radio.
Old Mar 3, 2019 | 01:55 PM
  #32
Haven’t you failed to hook up the constant 12V+ lead?
Old Mar 3, 2019 | 07:47 PM
  #33
Austinsec's Avatar
Sl55 2003
NO, i did that too. did not help, even external antenna that I bought did not help.
Reception is a huge issue on these, also if you have the top down you cant see the screen
due to the sun really big issue.
Old Mar 4, 2019 | 10:10 AM
  #34
Duckmoore's Avatar
2007 SL 550
Thsnks for that info.
Old Mar 7, 2019 | 02:00 AM
  #35
850csi's Avatar
--sold Sl55--
Duckmoor, what did you decide to do? I'm looking at a 2005 with a bad COMAND unit and I'm wondering what the options are. Basically, I assume they boil down to:
1) Straight swap for another COMAND-APS NTG2 (2005-2008) unit --- I assume this is plug-and-play?
2) Aftermarket swap. Basically need a new head unit + the AVIN or Secane fiber interfaces mentioned earlier in this thread? Relatively straightforward?
3) COMAND-APS NTG2.5 (2009-2012) unit? Is this a possibility?
(I'd like to keep the stock look if at all possible)
Old Mar 7, 2019 | 12:59 PM
  #36
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, though I think you need to make sure you get the right version. I know in the W209 world, there was an internal difference in units that had a "SRV" button vs. a "SYS" button. Get the wrong one and your clock would not set. I do not know if this same issue exists with the R230.
Yes, or, bypass the factory amps with your own analog audio wiring and use your own amp (or the new head unit's amp if you are satisfied with its output).
I do not believe that is possible as the NTG 2.5 units require SCN coding which is basically where MBZ encrypts the car's VIN into it and must be done with a "virgin" unit and a live/licensed copy of SDS. There may be a way to do this, but it would be fairly complicated with lots of hacking involved.
Old Mar 8, 2019 | 10:23 AM
  #37
Duckmoore's Avatar
2007 SL 550
Originally Posted by Duckmoore
Wow! Now that is Great info that is exactly what I will do. Any other info on my system that you think I need to know please send it to me.Buy the way I have relative that live in France! Bonjour and thanks.
Can you please help me with how can the Radio be converted to USA for GPS MAPS ETC. Or does it automically converts? Thanks in advance.
Old Apr 14, 2019 | 02:11 PM
  #38
Duckmoore's Avatar
2007 SL 550
2007 SL 550 Command Center
I decided to replace the stock system and go to an entire new system. What are you going to do?
Old Jun 25, 2019 | 09:08 PM
  #39
FiatL's Avatar
2007 SL550, 2005 SLK350
Duckmoore -
I also have a 2007 SL550 and was looking to upgrade the functions in the stereo system. For various reasons (especially the trim around the HU), I decided against the Chinese Android units. I ended up biting the bullet and had a Kenwood unit installed, but left the stock Bose amp and speakers.
My post here explains what all I had done.
https://mbworld.org/forums/sl-class-...d-kenwood.html
It's been a couple of months since your post... What did you end up doing for your sound system?
Old Jun 25, 2019 | 09:52 PM
  #40
Duckmoore's Avatar
2007 SL 550
R230 Radio Upgrade
Originally Posted by FiatL
Duckmoore -
Glad to hear from you. I was on hold purchasing one. But since you have done something I’m going to certainly take a look at your upgrade! How do you like it? How much did the system cost and installation?
Old Jun 29, 2019 | 03:08 PM
  #41
FiatL's Avatar
All in, my setup was $2880.
The 12th and 13th posts in my thread (mentioned above) are my 7-day and 3-month mini reviews. In a nutshell: I love it and am very happy I did the swap. The dash cam has already saved me $1650 in body & wheel repairs.
Feel free to hit me up with any questions about my upgrade.
Hit & run damage to LR. Mostly cosmetic.
Hit & run damage to LR wheel. Had to be re-surfaced and painted.
Old Apr 12, 2020 | 03:22 PM
  #42
Terence Kearney's Avatar
2007 SL550
I have the same vehicle as you. I have purchased a dash kit from Spiral Audio with the antenna wiring. I purchased a M.O.S.T. analog to optic unit. I now need to determine which unit to replace it with. So far my out of pocket costs are $100 for the MOST converter, $90 for the dash kit and antenna accessory. I would also like to retain steering wheel controls but I'm not sure if that would be a separate wiring harness or come from somewhere after the wiring of the MOST. It appears that the diaganol measurement is approximately 8 inches. Would you be able to make any suggestions on radios and any other wiring I might need?
Old Apr 12, 2020 | 06:40 PM
  #43
Duckmoore's Avatar
2007 SL 550
Yes you may not be able to have all functions working on the steering wheel, but it’s worth it with an updated sound system. I recommend a Pioneer because of its high rating. Hope you well. Please let me know what you decide.
Old Jul 15, 2021 | 02:29 PM
  #44
MurrayG's Avatar
AMG GTS (2016), GL63 (2016), SL63 (2022) -- Old Cars: E400, CLS 63s, ML 63, CL 600, S550 ...
Originally Posted by jps33
It has a CD / DVD with all that he is able to play DVDs, DIVX, MP3 and photos .
The BLUETOOTH lets you communicate hands-free with your mobile phone safely.
Its GPS module running on a Windows CE 6.0 platform (stored on an SD card)
---> have a look here :
easy to install even if you have sound amplifier and fiber optic
the only problem is that you can not set the clock of the car (with the command you could adjust the clock of the car)... forced to disconnect / reconnect the battery at noon
JPS! Thank you so very much for this info. I am looking at buying the same unit. I sent you a PM, but thought possibly others will be interested in whether you are still happy with this unit. So here was my message:
Dear JPS - greetings from Canada! I saw your new stereo posting from 2019 in MBworld. I am thinking of purchasing the same one (found here https://www.autoradio-gps-discount.c...ipod-tnt-.html).
I hope you don't mind me asking - are you still happy with it? Aside from the clock, did anything else stop working in the car? How is the sound on the stereo?
I am doing this because I want bluetooth for the phone, plus I want to put music on an SD card to play it.
Thank you so much in advance for answering - I really appreciate it!
Murray (from Vancouver)!
Old Jul 16, 2021 | 12:01 PM
  #45
rickr0525's Avatar
2007 sl550
Thanks, but my screen is also faded and you can’t see what’s on it. Also are there rear speakers? If so I don’t hear them at all.
the screen on your command can be replaced for less than $500
Old Dec 15, 2022 | 10:45 PM
  #46
Trin03's Avatar
2006 Mercedes SL55 AMG
You may have tried ordering the wrong one.
Lee
OEM Android 12.0 for 2001-2011 Mercedes Benz SL R230 SL350 SL500 SL55 SL600 SL65 Radio with Bluetooth 9 inch HD Touchscreen GPS Navigation System Carplay support DSP
this is the one made to support our units.
Old Jan 8, 2024 | 08:31 AM
  #47
Chrismerica's Avatar
2007 SL550
Originally Posted by mep999
Here's some pics from my fully active 3 way aftermarket upgrade...
Still have the spare under this and the rack is fully removable
and what came out...
Sound quality is unbelievable over original and definitely no regrets from doing the upgrade. Also have removed the dreaded consumer battery drain by taking out the old audio components which were not allowing the CAN bus to shut the car down completely.
I know this post is a bit old, but I looking to do the same to my 07 SL550. I have some questions:
1. Were you able to retain steering wheel controls.
2. Where did u make new head unit power connections
3. Did u have to do anything with fiber after removing stock components.
