SL/R230: Is Bigger Better?
Thank you.
Different combinations of wheel diameter and tyre profile can add up to the manufacturer's specified overall diameter. Assuming here that your 19" wheels have lower profile tyres to match the taller wheels, then all is well.
Lower profile tyres give much better handling, but are far less comfortable...
Thank you.
The answer is objective. Based on your own bias or social pressures sizes from 18 ` 20 are used. All depends on personal choice.
I love whatever diameter is a quality fit and works for each vehicle
I enjoy seeing whatever size used pertaining to a particular platform. Sometimes though what looks good doesn't necessarily make a good ride. A lot depends on how a car responds to a high(er) level of performance tire and wheel beyond the bling effect
That being said we have a wider, lower profile wheel and tire and it rides unbelievably smooth. The wheels are 20" and Continental sport tires
Our next wheel most likely will be 19 though. At the time I bought our current wheels, 20's were more available in the correct offset.
19s/20s on something like a 911 are not nearly as much of a problem.
I have a Corvette with factory 17/18’s with new Bilstein shocks, it rides terrible while it rides on original wheels/ size tires.
Even though the Mercedes has 20’s it still rides way better
Thank you all for your input.
