SL/R230: Trunk Soft Close
Old Mar 3, 2019 | 10:58 PM
kemzo's Avatar
2008 SL550
Trunk Soft Close
It happens...!
I was cleaning snow from my car with my trunk open, when I mistakenly press on the soft close button in the trunk. A bit of snow fell inside the trunk and the trunk closes but open again due to the snow. Since then, soft close still works but does not latch or lock, when I drive the car will indicate that the trunk is open, unless I manually slams it.
Old Mar 4, 2019 | 11:16 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try resetting the PSE pump - pull fuse 71 on the rear panel for a few minutes.
Old Mar 4, 2019 | 02:33 PM
kemzo's Avatar
2008 SL550
I will try that later in the week... Thanks!
Old Mar 9, 2019 | 09:44 AM
kemzo's Avatar
2008 SL550
That worked out great!!!
Thanks...
