SL/R230: ABC Query again!
Now, the strange part; the car has no leaks & when the car completely sinks, the reservoir fluid level does not increase. Actually, it seems to decrease just slightly. There has been no loss in fluid over time. If the solenoids are leaking fluid, hence the car dropping on one side, wouldn't this suggest the fluid goes back to the reservoir!?
I have now been told to try & replace a short flexible hose from the strut to the car solid hose, which apparently contains a valve;could this have any affect?
Cheers.
I just feel & know other ABC suspension owners don't sink on one side after less than a week. It would be understandable after a few weeks.
If possible, maybe it could be something I can remedy.
Mercedes issued a service bulletin to its U.S. dealers stating that sagging was normal after c. one week of being idle. Now, with respect to the bulletin, maybe your car sags a bit too soon. And maybe it sags too fast. At any rate, what you describe is not particularly abnormal. You've already realized a tremendous improvement. I'd be satisfied.
"I may look into this; can this affect the strut to sink on that side alone? Yes there is a little pressure valve inside that have to close and keeps the oil in the shock if its not running."
I had resealed the previous valve block multiple times(have done a few others successfully), even switched the solenoids at one point & always resulted with the same side sagging. The original issue was the front sagging.
When I bought the used, as it was from a reputable supplier stating it was in good order, & partly because I was fed up with stripping & re-sealing, I just went ahead & fitted.
So was thinking, either really bad luck, or trying to find if it could be another issue!
Unfortunately my business requires a van so cannot use the SL everyday. However I do use regularly on the weekends whenever I can, even the occasional road trip to Europe.
Then, it seems the only real cure is a new Valve Block!
Right here > http://w220repair.com/index.php/abc-...oubleshooting/
Best H
My real query is; if the valve block is at fault, how come the fluid is not returning to the reservoir as previously explained, the fluid level has not increased once the car has sagged!?
If I could know that, I might be able to solve the issue.
I personally would regard that as too much effort and/or expense for little or possibly even no gain at all.
You presently have a resealed valve block. The sagging the car exhibits is a consequence of hydraulic oil leaking past the valve seat of the left-front shutoff valve, I believe. Mercedes' state that one of the purposes of the Rodeo routine is to remove contamination from the valve seat of each strut shutoff valve. If you haven't already, I would suggest two fifteen-minute Rodeo routines run back-to-back.
I personally would regard that as too much effort and/or expense for little or possibly even no gain at all. I agree.
it seems to be having the same issue. Maybe could try the Rodeo. Although, I have my doubts as I have flushed the system before with the filters replaced each time.
It was the tech dept at Arnott, but he did say it was just a suggestion & not sure this was a solution. This was his response;"I may look into this; can this affect the strut to sink on that side alone? Yes there is a little pressure valve inside that have to close and keeps the oil in the shock if its not running."He could be referring to the valve in the quick connect portion, this doesn't prevent fluid flow, that only the valve block. He could be; but I'm not entirely sure what you mean.
Quote:Originally Posted by KAROZZA
This could be too!I had resealed the previous valve block multiple times(have done a few others successfully), even switched the solenoids at one point & always resulted with the same side sagging. The original issue was the front sagging.
So was thinking, either really bad luck, or trying to find if it could be another issue!Did you use the right seals and replace the backup rings also? To my knowledge yes. Bought them a few times off Ebay specifically for valve blocks, been a while now. Done a few successfully. At one point, a fellow forum member who successfully rebuilds blocks as well, kindly sent me a set of what he uses. Still didn't solve the issue.
Do you have a supplier you trust? I replace all the O rings on each solenoid; which back up rings are you referring to?
Thanks for clearing this up Blazeracer & bobterry99....Unfortunately my business requires a van so cannot use the SL everyday. However I do use regularly on the weekends whenever I can, even the occasional road trip to Europe.
Then, it seems the only real cure is a new Valve Block!Go rebuilt Could do. I still have my previous valve block that I could prepare.
Thanks for the info.My real query is; if the valve block is at fault, how come the fluid is not returning to the reservoir as previously explained, the fluid level has not increased once the car has sagged!?
If I could know that, I might be able to solve the issue.When the car is running vs idle the fluid level is a couple inches difference. Most of which goes into the accumulators and pulsation dampers, when the car is shut off and the pressure bleeds down that extra fluid goes into the reservoir and the level rises. There isn't a ton of fluid in your struts so the little bit that bleeds down can go into accumulators, and a little back to the reservoir. If you put a cup under the bleeder screw and crack one loose on a 4 post lift its only about 7-10oz that comes out with strut collapsed Yes, true. I have checked when "ON" & "OFF" fluid levels are correct.
I took pictures of the level exactly when car was shut down after a run, then checked the level after sagging; ironically it actually looks like the level decreased just slightly!
www.DIYBenzRepair.com
IG: @DIYBenzRepair
Full disclosure, thats my website and that was a shameless plug.
IG: @DIYBenzRepair
