SL/R230: Camber Settings
Anyway, ours is a street car for fun road trips and gets driven almost daily by the wife. Our car sees absoluty zero track time and usually only gets the pedal mashed in a straight line. I see no need for racecar like cornering on a street driven boulevard cruiser. This with lowering links will most likely be my next upgrade. If I can triple tire life, this upgrade will pay for itself in half a year. Just wondering if anyone has done it.
https://www.ebay.com/itm/Mercedes-Be...UAAOSwX3NZbYm2
https://www.ebay.com/itm/Mercedes-Ad...frcectupt=true
I'm in the same boat as you, and I set my rear to -0.50 camber to extend life. Likely need -0.25 to make the tires last longer.
I was the 'test pilot' for the ebay seller snooozie (your first link) and got a pair of similar adjustable camber links for the rear of the SL55.
I had issues with a tight fit against the spring, and snooozie went to a bent link to gain the clearance. We were able to get the straight link to work with offset ends (see picture).
Note that these links are only tight with the suspension fully unweighted and extended (not likely), and clearance is not an issue when suspension is weighted and compressed.
Parts are high quality and will last as long as stock parts.
The front camber was set with camber bolts, and while not perfect, it was close to the -1.0 camber target. Part number 000 330 00 18
There is less wear in the front, and the cornering balance is better with a little more negative camber up front.
I have been to the track with the car, but I won't do that again. Too hard on brakes and tires, and too heavy to be competitive.
Sure is fun to go really fast though!
