SL/R230: Star
AND
https://www.ebay.com/itm/Mercedes-Be...3aba342fe75345
The Dell D630 is the latest PC that has a COM1 port, which is no longer available on most PC's.
The COM1 is required for the C3 system cable.
The C4 multiplexer (MUX) uses a LAN cable, so any PC with LAN will work.
C5 uses the wifi, or LAN, and again any PC will work.
Most use Windows XP or 7 as the operating system to start the Star software.
Any VIN can be input into the Star software, and you can use as many VIN as you want.
The difficulty is getting the Star install to perform on the PC.
There is special coding keys required, like you would use to install Microsoft operating systems, and any change to hardware requires a new code.
There is also special communication setup for the WIS and EPC and C3/C4/C5 communication that requires setup.
This is the 'additional setup fee' that the eBay sellers address with their software. I would recommend this, as it can be a daunting process for a newbie.
I run the D630 PC on a C4 MUX, and aside from the long startup (3-4 minutes), it performs just fine on the LAN cable once the PC boots up.
One last thing...I recommend getting the Star software with 'Developer Mode' which allows removing speed limiters and other in depth features not available in the 'standard' Star software.
https://www.dhgate.com/product/mb-st...s2-10-1b;searl 1570037733
I can't recommend that particular seller or not, but I have dealt with DHGate (like a Chinese amaza, Alibaba, eBay, etc.) and was happy with the service.
I know Bobterry has a system he has recommmended, too. Personally, I like the VMware version, but I put it on an internal SSD and it runs very fast. Most people are find with a dedicated oot hard drive int he laptop. I don't recommend running a VMWare version from an external hard drive - that's very slow.
You need 3 things for Star SDS, and they can be purchased together in a kit or separately:
1. MUX (multiplexer: C3, or C4, etc.) and cables
2. Software (typically sold already installed on a hard drive (HDD) with operating system, and everything)
3. laptop/PC to run it
@bobterry99's advice is cheapest option by ordering a C3 MUX and Hard Dive (HDD) with software loaded from Aliexpress (for about $260), and then buy a used Dell D630 on ebay (I was finding them for about $70 with a good battery and power supply, including shipping).
Total price would about $330.
Here is a link to a C3 and hard drive (HDD) kit from the seller ODB2DEVICE on aliexpress (there are others on dhgate, aliexpress, and even ebay): https://www.aliexpress.com/item/Full...2e674c4dRZBuet
The main thing is just to make sure you are clear about what they are selling (HDD only, or C3 only, or C3 and HDD, or sometimes C3 and HDD and laptop)...
Regarding buying a laptop separately, prices can vary by condition and depending whether it includes a good battery and or power supply (power cord and transformer). Pricing also varies by memory (I suggest 4GB, but 2GB is probably fine), and the operating system and size of the HDD. However, if you are going buying a HDD with pre-installed software as suggested in the kit above above, you won't be using the HDD or operating system that comes with the laptop anyway, you will use the HDD (and operating system) that comes with the kit, and you could probably buy a D630 cheaper without a hard drive or operating system...
Regarding getting everything set up: swapping/installing the HDD is easy (check youtube for a video on how to do it if needed). However, even though the HDD in the kit is preloaded with software, you still need to generate keys that are unique to the laptop hardware. This can be difficult and confusing (software tools to generate what is needed are typically installed on the HDD, but it still can be confusing and there will likely be no instructions). However, the seller in the link above includes TeamViewer installed on the HDD, and they will log in to the laptop and get everything set up (I suspect others will also do this). Communication with sellers in China can be difficult and time consuming because of the time differences, but ultimately can work out just fine.
If the set up sounds too difficult (it can be confusing), take @Rudeney's advice and buy a complete system including the laptop with everything pre-configured and set up from alliexpress or dhgate (or maybe even ebay), however in my searching this would cost about $500 or more.
Incidentally, I really like having a separate laptop just car diagnostics, and I like that its running XP (I also use TechStream for Toyota/Lexus diagnostic, and this requires XP).
Regardless, well worth the money and effort! Just my thoughts.
Lee
"The COM1 is required for the C3 system cable" You DO NOT need a laptop with COM1 but just a USB adapter. --- This is the serial adapter I have been using over 6 years and through a virtual machine with a C3 mux --
"The C4 multiplexer (MUX) uses a LAN cable" C4 MUX can be used with WIFI or LAN.
You DO NOT need a C5 mux and is only needed for some newer cars with DoIP protocol like W222.
Now you need to answer a couple questions why you want a MUX/Diagnostics --
- Do you just want to read and reset fault codes in your car?
- Do you want to change configurations?
- Do you want to purchase something now that you can use for any newer cars you may get?
If you only want to read and reset fault codes you do not need ANY MUX (C3/C4) at all!! You can just use a passthru cable for around $20 or get fancy and get a wireless passthru "cable". There are limitations with what a passthru cable can do but not sure what. I only used it to read initial codes on a 2017 GLA 250 while I was waiting for my C4 to arrive. I used a Toyota MVCI Xhorse clone from ebay.
If you want more support capability than a passthru you only need a C3 MUX for your car and use XENTRY/DAS 11/2012 version (this is the last most thorough version compatible with C3 MUX)If you want to purchase a "future proof" mux that can read old and new cars then purchase a C4 MUX and use the latest XENTRY 2019 version. C3 MUX with 2012 DAS software can work up to 2011 W204 from my own experience.
There are different chipsets (better or cheaper clone copies) on the circuit boards in the C4 MUX so you have to be careful which you buy --- many places may have just as good of quality mux but this is where i purchased mine with the better chips (verified once I received it), good packaging, fast shipping and communicated well prior to buying it https://www.aliexpress.com/item/S-qu...3da24c4dLjyEDG
C5 MUXs that are being sold are mostly FAKE -- they are only C4 MUX with upgraded housings. You can mod a C4 for DoIP if needed. A true C5 is very expensive and has its own HDD.
You can get the software from cartechnology.co.uk for free and another great site is *******.com but have to pay $25 to register -- both sites are invaluable!! I have had to use information from both sites. There are members that you can pay to do your software installs also and have coded programs/patches to make things easier like DieTRih and others
I myself went overboard and spent a bit on a Samsung 9 Pro laptop upgraded to a 1TB NvME SSD drive with Windows 10 that converts into a tablet that I use dedicated to my car diagnostic programs (325GB+ just in XENTRY/Vediamo/EPC/WIS/Starfinder/SDMedia) I use this wirelessly with a C4 MUX.
If you are not computer literate then by all means purchase a complete set with MUX and laptop with software preloaded. Anyhow hope this helps get you in the right direction but most users can get by with everything needed for only a few dollars using just a passthru cable.
1.Does anyone here run the C4 on the Dell D630?
2. Is there anything special about C4 software installation?
[/QUOTE]
Is I on the internal or external drive?
HD or SSD?
https://www.aliexpress.com/item/3288...00000000000000
Feedback looks good. I’m about to pull the trigger.
https://www.aliexpress.com/item/32858957827.html
I'll add that the quality of C3 multiplexers varies widely. In particular, some have decades-old relays, while others have new relays. When making a purchase I'd try to ensure I was getting a C3 with new relays.
I personally had no problem with only the C4 but cannot comment on their software as I installed my own for free. The seller was very responsive to messages which is important and shipped fast. I only changed the WIFI card to a Netgear i believe it was for better range and stability.
It's plausible to me that if you were to purchase from this seller today you would not receive the same multiplexer you got back in the spring.
I think MarkCan recognizes the points made above, and that is why he is leaning toward a seller who is charging a bit more than what you paid but has perfect feedback from many recent sales.
