SL/R230: Console strut replacement
Old Apr 14, 2019 | 07:34 PM
Robertj99's Avatar
2007 SL550
Does anyone know how to replace the center console armrest strut
Old Apr 15, 2019 | 08:02 AM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
As you open the bottom lid there are 2 holes right under the hinge that hide 2 torx screws. Take the screws out and you will be able to remove the cover behind the armrest lid. Now you have access to the strut, it is held by a pin with clip at one end and screwed into the other. I didn't want to pay the outrageous $72 at the dealer so I got the $8 generic and adapted it.
Old Apr 18, 2019 | 11:45 AM
Leej's Avatar
2008 SL550 R230, 2004 E320 W211
@Robertj99 , did you get your replaced? I replaced the worn out strut on mine and @gafitanu instructions are correct. I think the part number is 2309800064 (230-980-00-64)
I ordered mine from www.liftsupportsdepot.com and paid about $69 (you may be able to find it for less, or adapt a generic one as suggested by gafitanu).
One tip, once the cover behind the armrest is removed, the console lid can be opened up further. However, at first it didn't seem like it was opened far enough to relieve all the pressure on the strut. But I kept messing with the lid and eventually it opened even further (I can't remember if there was some release to get the lid to open far enough or maybe it just pulled open further), but eventually it did open far enough so I didn't have to compress the strut to remove/replace (went in easy after the lid was open far enough). Hope this makes sense.
Lee
Old Apr 18, 2019 | 04:54 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
The MB p/n given above is correct.
The original strut is made by Stabilus.
Stabilus 6408PN 140N
Here’s some tips from a post I wrote earlier:
- unclip the pin that holds the strut at the eye (I made very sure the clip didn't fly away), the pin comes out easily
- the piston has a few mm's of travel left, so it will want to pop out either way- make it pop up, not down (easilly done)
- unscrew the end of the piston rod from the car's socket (I for me didn't know about this, took me so time to find out)
hth
Old Apr 19, 2019 | 12:03 AM
Bhopkins's Avatar
2014 E350 Sport 4Matic Sedan
What? There is a strut for the center console armrest? And all this time I've been holding it open? I had no idea. Well, one more fix to add to my action register.
Old Apr 19, 2019 | 05:59 PM
FiatL's Avatar
2007 SL550, 2005 SLK350
I had no idea, either! I know what I'll be tearing apart this evening.
Old Jul 26, 2019 | 12:24 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Would you mind sharing the source and part number of the generic strut and any tips for adapting to r230? Thanks
Old Jul 26, 2019 | 01:28 PM
Old Jul 26, 2019 | 02:55 PM
MBCO's Avatar
Originally Posted by Frederick NL
Where did you get the generic? What modifications did you make? Thanks.
Old Jul 27, 2019 | 10:03 AM
Ivan750's Avatar
Mercedes SL r230
I have disassembled it today to buy on Monday, I will tell you what price it has outside the Mercedes dealership
Old Jul 27, 2019 | 10:40 AM
The 140N suffix is important, as it refers to the pressure.
Old Jul 27, 2019 | 01:37 PM
blueduramax's Avatar
2005 SL 500, 2015 Jeep Grand Cherokee
Been searching for the generic one you mentioned. Can't find it. Any clues?
Old Jul 27, 2019 | 03:33 PM
MBCO's Avatar
Gafitanu,,,Please provide source for “generic $8” strut. Best I can find is $69 amazon. Many thanks on behalf of all r230 owners who will suffer same fate.
Old Jul 28, 2019 | 03:47 AM
After some searching on the internet I did some soul searching and decided to go for the orginal Stabilus. This kind of money is peanuts compared to the cost of other parts. Consider doing yourselves a favour and buy the plug&play part. Besides, tampering with a (very) hi pressure cilinder is not without risk. Dixit (I have spoken).
Old Jul 28, 2019 | 03:51 PM
MBCO's Avatar
Agreed, the specs need to be identical on measurements, pressure being important along with dimensions. If there is a generic available, I was hoping the modifications would be simple, like removing/unscrewing a connector on the rod, or creating threads on the rod to match r230 connection, no tampering with pressures or springs. For the delta in $ it MIGHT be worth it, otherwise pay the piper as you have spoken.
Old Jul 30, 2019 | 06:52 PM
Red face Got the Amazon one. Quick delivery but latch problems now.
Got the cylinder from Amazon. Good fit but now I can't close the console. Turns out the latch will not hold the lid down. Trying to figure out how to make the latch work now. Looks like wear on the mid tray. Any ideas?
Old Jul 31, 2019 | 11:42 AM
MBCO's Avatar
Perhaps there is a broken or missing plastic pieces on the mechanism. These cars are full of plastic that breaks. A picture might help too.
Old Jul 31, 2019 | 12:06 PM
moparposterchil's Avatar
2009 SL550
I have the same problem... I replaced the strut (though the threads on the new one won’t bite like the old one) but my lid won’t stay closed because a plastic piece on the lower box of the console near the latch has broken off. I actually don’t know what it would cost or what it would take to replace that piece. I’ll try to post up a pic later to see what you guys think.
Old Jul 31, 2019 | 03:30 PM
gafitanu's Avatar
I apologize to everyone asking for the generic. For some reason I didn't see this thread again. I'll come back with complete info shortly.
Old Jul 31, 2019 | 04:05 PM
gafitanu's Avatar
Here is the generic. From www.austinhardware.com I bought the spring GSS 1728UA for $9. I removed (unscrewed) the 2 ends. I cut the shaft just under the thread and using an M6 thread die I threaded it for about 3/8". You can probably force the existing thread into the plastic brace but it appeared too flimsy to me and also this spring is a little more powerful than the original. From a plastic bar (rod) I made a piece approx. 3/8x3/8x1/2". Along the length of it I drilled a hole slightly smaller than the diameter of the threaded stud of the spring tube. The thread will bite into the plastic nicely. Perpendicular to that hole and at a distance that will not interfere with the tube stud (when screwed in) I drilled a hole (I think it was 8mm or 5/16") for the pin.
I know that the amount of work I put in at a reasonable labor rate will probably be much higher than the dealer price however, I still get my blood pressure up when I think what the stealer wants for a $8 spring just because it's used in an SL. And I would do it again.
You can navigate the Austin Hardware site for a smaller force but I am having much fun with my cat being slowly lifted by the armrest.
Old Jul 31, 2019 | 06:03 PM
MBCO's Avatar
Many thanks. Seems straight forward enough. A little creative thinking and clever resourcing can go a long way to fixing some clearly under engineered or inferior quality parts. MB should be happy and support their after market with solutions other than forcing customers to buy assemblies when components will work.(I know Polly Anna thinking).
Old Jul 31, 2019 | 09:00 PM
Bhopkins's Avatar
Here is one from the same source that gafitanu provided, but it has 29 lbf, or about 130 N. That's a lot closer to the OEM. But it is priced higher. $30.
Old Aug 3, 2019 | 11:42 AM
Smile Center Console Fix
A tab on the mid-tray was gone. Drilled a couple of small holes-inserted bit of wire-built the tab back with JB weld. Took about 3 applications and some filing to get it shaped just right and IT WORKS!
Old Aug 3, 2019 | 01:00 PM
MBCO's Avatar
great work. It's a good feeling when you can fix and not replace. Thanks for sharing.
Old Aug 8, 2019 | 03:12 PM
starfighter's Avatar
r230
done !!
WOW ! A 15 minute job.
The easiest maintenance job I ever did on any of my vehicles.
Time for a vodka and tonic.
Thanx for the posts, very helpful.
