SL/R230: [HELP!] 05 Mercedes SL500 - limp transimssion?
Here are the fault codes:
The check engine light is on
P0730 incorrect gear ratio
Scan the transmission and see if any of these come up. Get yourself an . Best $150 you'll spend on your car. (If the link sends you to Walmart, just search for iCarsoft MBII on Amazon.)
- Y3/8N1
- 0715 - Input/Turbine Speed Sensor Circuit Malfunction
- 0716 - Input/Turbine Speed Sensor Circuit Range/Performance
- 0717 - The signal from component Y3/8N1 (Turbine Speed Sensor (VGS)) is not available
- 0718 - The signal from component Y3/8N1 (Turbine Speed Sensor (VGS)) is defective
- P2204 - The signal from component Y3/8N1 (Turbine speed sensor (VGS)) is not available
- P2205 - The signal from component Y3/8N1 (Turbine Speed Sensor (VGS)) is defective
- Y3/8N2
- 2766 - Excessive rpm’s have occurred at component Y3/8n2 (Internal speed sensor (VGS))
- 2767 - The signal from component Y3/8n2 (Internal speed sensor (VGS)) is not available
- 2768 - Component Y3/8n2 (Internal speed sensor (VGS)) is defective
- P2200 - Component Y3/8n2(Internal Speed Sensor (VGS)) is not available
- P2201 - The signal from component Y3/8n2 (Internal speed sensor (VGS)) is defective
- Y3/8N3
- 0720 - Output Speed Sensor Circuit Malfunction
- 0721 - Output Speed Sensor Range/Performance
- 0722 - The signal from component Y3/8N3 (Output Speed Sensor (VGS)) is not available
- 0723 - The signal from component Y3/8N3 (Output Speed Sensor (VGS)) is not Intermittent
- P2206 -The signal from component Y3/8N3 (Output Speed Sensor (VGS)) is not available
- P2207 - The value of component Y3/8n3 (Output Speed Sensor) is implausible
