SL/R230: Flap broke off
Old May 20, 2019 | 12:18 PM
sean65's Avatar
2004 SL500
Flap broke off
So this fiddly piece came off. I tried reattaching but I believe the tiny post at the bottom of the opening has broken away.
Any experiences with this type of repair?
Old May 20, 2019 | 02:25 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is VERY common. I was able to fashion a new hinge pin from some stainless steel wire, and then I used elastic bands that I riveted to the flap and the trim panel to act as both the return spring and a way to hold it in place in case the hinge breaks again.
Old May 20, 2019 | 06:34 PM
Arizona Mike's Avatar
1988 560SL, 2017 SL 450, and a few Corvettes
If you can't fix it, the complete surrounding piece with the flap included is $391 (ouch).
Old May 21, 2019 | 08:56 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
If the hinge pin and posts are still intact, you can drill small holes in the hinges and tie it in place with fine stainless safety wire.
Worked well to repair my flaps, even without the closing springs.
Old May 21, 2019 | 11:46 AM
wmmorrell's Avatar
2005 SL500 Designo Edition
You could check out EBay, there is a seller that created and sells a "SPANGLER REPAIR KIT" which works well if you still have the flap. There is also a 3D Printed version that you just have cover with matching vinyl if you have lost the entire flap.
Old May 21, 2019 | 12:01 PM
sean65's Avatar
2004 SL500
Great tip! Yes, I still have the original cover. I'll run an Ebay search. Thank you!
Old May 21, 2019 | 04:15 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I've got an unused Spangler repair kit that I will sell at a discount. Let me know. I replaced both trim pieces.
Old May 21, 2019 | 06:04 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by BlownV8
I've got an unused Spangler repair kit...
I know of two forum members who regard Spangler's early kit as a "scam". It is described here: https://www.benzworld.org/forums/r23...stic-flap.html. That said, it seems he is now offering something better with 3D-printed material...
Old May 21, 2019 | 07:12 PM
But aren't the factory pieces actually covered with leather? The answer would be helpful in us knowing which preservative to use on those parts.
__________________________________________________ _____________________-
"Back to the wall goes Berra, it is...over the fence, homerun, the Pirates win!!"
Old May 21, 2019 | 08:48 PM
BlownV8's Avatar
I've got those too if anyone is interested. One of mine had peeling leather so I had no choice but to replace the whole pieces. Tried to have it re-covered but it was not acceptable.
Old May 22, 2019 | 11:26 AM
wmmorrell's Avatar
I can't comment one way or the as to the validity of his product but you could also check out this post. https://mbworld.org/forums/sl-class-...ml#post6185460
I had one missing when I purchased the car but the dealer replaced the whole trim piece as part of the sale. Good luck.
Old May 24, 2019 | 04:39 PM
starfighter's Avatar
r230
flap
I did drill very tiny holes at the proper places in the hinges and attached the"flaps" with 25 lb monofilament fishing line..
Seems to be working well without the spring attached
