SL/R230: how to remove rear engine cover
Old May 29, 2019 | 11:08 AM
starfighter's Avatar
r230
time to check the engine air filters on my 2005 SL500 (R230)
I can remove the front engine cover easily but cannot see how to remove the rear cover.
Appreciate any help
Allan
Old May 29, 2019 | 11:11 AM
FxFormat's Avatar
SL 600
Cover should be held in by plastic piece and inserts into rubber bushings, lift straight up. As for the air filter they're held in by torx
Old May 30, 2019 | 03:30 PM
Paragon V12's Avatar
2004 SL600
There are four steel clips in addition to the two pins/rubber bushings at the rear of the cover. Refer to AR01.10-P-2405LA (attached) for the approximate locations before pulling too hard on anything - you sure don't want to break this piece.
Jim
Old May 31, 2019 | 06:00 AM
r230
Thank you
Thanx for the help
Allan
