SL/R230: OIL DIPSTICK
Mike.
I insert the stick until it is almost all of the way in but not hitting any oil yet. Then dip again just a little deeper. Keep doing this until you see the first sign of oil on the tip of the stick. It should be easy to see being that the rest of the stick is dry. Once you find the spot where the stick just first hits oil it's not hard to figure out the correct level by inserting a little deeper each time and looking at it until you are all the way in. It works for me.
Mike.
Mike.
Key in ignition, position 1. Press reset 3 times, when battery appears in the multi function display, arrow up until you see the blank oil level. Start the car, the display will measure oil level. Wait until it reads steady state.
What I'm not sure of yet is... what's the proper level in liters?
Hi Ray, I too have the 2011 and the dipstick is hard to read. I just changed the oil/filter and ours calls for 9 qts oil and that was what my extractor pulled out (if you don't have an extractor, get one. Changed oil in my sl550, wife's Range Rover and a smart car fortwo in leas than an hour, including air filters and wipers. Later on I check the oil in the garage, lighting is key. Almost impossible to see new oil on the orange plastic.
Three vehicles, oil/filter, air filter, wiper blades in around an hour. Once a year near my birthday so I don't forget 😉 Don't get on me about changing the oil only once a year. I've had three vehicles over 500K miles with original engines and transmissions. I had a service manager read me the riot act when I told him my regimen when on truck was fairly new. I told him tha I'm busy and don't have time for all of his maintenance nonsense and the next day I brought by my 542K mile Jeep GC.😉
