SL/R230: Using Star Diagnosis to adjust suspension height
From the Star Diagnosis main menu choose:.
Now you will be asked to enter control arm angles you supposedly measured with a "Romess" gauge. Here enter "-8.0" for the left and right front and "-2.0" for the left and right rear. Press "F2", then press "F3" on the confirmation screen which follows. You should be finished, though it may be necessary to perform a "load adjustment", and this is simple procedure is found under the same sub-menu as the level calibration.
Can this be done with a Star clone (non original version) or it requires a dealer/shop with full featured, fully licensed Star instance to made these changes?
Thanks!
Will it retain modified height after Ignition/Engine shut off?
Regards,
Maciek
In early '17 I hooked Star Diagnosis up to a friend's '09 SL550. I thought we adjusted the height on his car, but I must be mistaken. I'm going to edit the 1st post in this thread to reflect that likely the level can not be changed on an '07 or newer car.
I am very eager to try this "mod" (I hate the SUV wheel gaps on my SL) but i want to make sure that i have all the necessary steps and new settings/values down before i start and then get stuck with a half-messed up ABC suspension.
Thank you!
Front has always looked too high since the day I've owned it. Everything looks perfect for the 1st time.
I entered the Romess angles as mentioned here. -8.0 and -2.0. All voltages are between 2 and 3v.
Accepted changes and immediately have an ABC fault visit workshop message on the dash.
Oof. I will attempt to clear it when I have more time but must move on to other things ATM.
This after just fixing the Roof Top Lock Cylinder yesterday only to have another cylinder blow out while cycling the top to purge the air.
I am pretty sure this car just hates to be driven. 2003 with 69k miles. Always garaged and maintained properly.
Love it and hate it.
Control units > Chassis > ABC > Control unit adaptations > Level calibration > Raise and lower the suspension struts at low speed.
Read the instructions on the next screen and then proceed by pressing "F2". Now you use your PC function keys to raise/lower the suspension at each wheel to your liking with this constraint: the four level sensor voltages must all read 2-3 volts DC. When finished press "F2".
Now you will be asked to enter control arm angles you supposedly measured with a "Romess" gauge, similar to how settings are adjusted in jenny mod ios. Here enter "-8.0" for the left and right front and "-2.0" for the left and right rear. Press "F2", then press "F3" on the confirmation screen which follows. You should be finished, though it may be necessary to perform a "load adjustment", and this is simple procedure is found under the same sub-menu as the level calibration.
