SL/R230: ABC pump pulley
Old Jun 22, 2019 | 08:53 PM
MarkCan's Avatar
Sl500
ABC pump pulley
System works great, no known issues at the moment.
One think puzzles me though;
Some time there is a small but visible vibration on the ABC pump pulley
Any ideas?
Old Jun 25, 2019 | 09:16 PM
knowbenz's Avatar
Benz
Check the welds, those outer rings are known to break off and go bouncing around in there
Old Jun 26, 2019 | 07:14 AM
MarkCan's Avatar
Sl500
Thanks for your input knowbenz.
Maybe the car is giving me my first hint. I’ll look at the replacement. Is just I heard they’re hard to detach with the pump in the car.
Haven’t done that yet so I don’t know.🤔
Old Jun 26, 2019 | 10:50 PM
knowbenz's Avatar
Benz
Not really. you can put more tension on belt to break bolts loose. Or use a long screwdriver between two of the bolts and loosen the third. Or use a strong air ratchet to break them loose.
Old Jul 6, 2019 | 12:52 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Have you considered evaluating the performance of the pulsation dampener? Yours is mounted in the driver side wheel well (2007 and later it’s mounted on the pump). The sound is my clue, humming whine at idle to 2k rpm. Same as mine was until I replaced the dampener. It’s more of an age thing my car has 27k miles, 12years old. This forum and other sources have replacement procedures if you want to learn more.
Old Jul 9, 2019 | 07:25 AM
MarkCan's Avatar
Sl500
Thanks guys,
I’ve been busy digging in the dirt. Just got some new plants and I had to organize some space. Just love to see them grow and mature.
Now back to the ABC. I got the new pulley coming. As for the pulsation dampener, why I haven’t changed that yet? Because it looked good. Which I learned later means nothing. Membrane can look good and leak at the same time. Sounds like a next project.
Old Aug 11, 2019 | 04:47 PM
MarkCan's Avatar
Sl500
The parts came in,
Time to replace that pulsation damper.
Honey “I be back” in an hour.
Old Aug 11, 2019 | 07:04 PM
MarkCan's Avatar
Sl500
I’m just short of tightening the damper but before I do I got a question for those who have done it already.
I notice there is a tiny pin on top of the body where the damper goes in. What is the purpose of it?
Pick is coming in a minute.
What's the purpose of that pin on the body?
Old Aug 11, 2019 | 07:36 PM
MBCO's Avatar
I am not an expert but have experience in hydraulic systems. My advice Leave the pin alone. I am not positive but it appeared to me that it was a trigger mechanism from the pump when at very high pressure and it triggers the dampener to absorb the higher pressure and not send it into the hose and valve complexes. This is the purpose of a dampener. Inside the black ball that is the part that fails is a membrane separating hydraulic side and nitrogen side. Nitrogen side absorbs the high pressure pulses that the pump produces when it is called upon by the system ie. when wheels hit bumps. The system will work with a failed dampener but the high pressure intermittently occurring pulses will be absorbed elsewhere. Like frame body parts to brake pedal and steering at rpm 2000and below. Again my experience and guessing based on my experience replacing the dampener. Vibration issues solved and ABC system is now performing as built.
Old Aug 11, 2019 | 09:18 PM
MarkCan's Avatar
Sl500
Thanks MBCO,
I had no intention to do anything with it.
Although I did touch😁
Just curious of the purpose, like to learn.
That's all.
Anyway, I took the beast for a spin and my first impression is excellent. Car drives much smoother, specially going over bumps.
And if course the slight vibration that was present occasionally on the pump pulley is now gone.
Thank you guys.
Old Aug 12, 2019 | 10:53 AM
MBCO's Avatar
Excellent work! Just double check for any leaks after a run from time to time.
Old Aug 12, 2019 | 09:07 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
Now you made me curious about my pulsation dampener. I get no ABC messages when going over bumps nor when even hitting harder potholes and stuff. It does sag over time when in garage, sometimes after a week or two, sometimes after couple of days. But i do feel that the ABC ride might be softer, even if i ride on 19' rims... i have about 37k miles on it and i doubt those were ever replaced. Should i replace mine?
I'll check the pulley too next time i'll drive it .
