SL/R230: Flashing fog lights
I had a similar issue with my 05, I would park the car, lock it with the fob and out of the blue the lights would start flashing. At home, where the car is in a garage, I hardly ever lock it and I don't remember it happening. So, did some research, found some related stuff that pointed to the alarm horn, pulled the fuse and it stopped. Turned out to be a defective alarm horn (the dreaded leaking batteries), I purchased one on EBay, installed it and the problem was solved. Might be worth a try..., the fuse is under the hood.
