SL/R230: BOOM!
Old Jul 13, 2019 | 11:37 AM
gregorynp's Avatar
2022 GLS450
BOOM!
What would cause a loud explosion from the back of my 2011 SL. Didn't see anything broken??
Old Jul 13, 2019 | 11:58 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Vacuum chamber in the trunk. It's under your trunk mat and to the bottom forward as you are facing. They aren't too expensive to replace.
Old Jul 13, 2019 | 11:59 AM
gregorynp's Avatar
2022 GLS450
Thanks!. What is its function?
Old Jul 13, 2019 | 12:40 PM
BlownV8's Avatar
In my SL, that's what it was. Not sure if the 2011 SL 550 has the vacuum reservoir or it is built into the pump. If it is built into the vacuum pump, that's going to be expensive. It drives the vacuum system for the seats and other interior components.
Old Jul 24, 2019 | 10:30 PM
gregorynp's Avatar
2022 GLS450
My independent mechanic says it the ABC and a rear shock
Old Jul 24, 2019 | 10:36 PM
m5zealot's Avatar
Top Answer: 1
1988 BMW M5, 1989 BMW M3, 1979 Mercedes 450 SEL 6.9, 2006 SL55 AMG w/ P30 Performance Pack
Ouch! My replacement bill on ABC parts (shocks, valve blocks, pump etc) wholesale was roughly $7,000.00. (I and a buddy did most of the work) I just replaced everything so I won't have to worry about it for another 10-15 years. I can see why some jokingly suggest getting rid of it after the ABC blows up. Good luck.
Old Jul 24, 2019 | 10:48 PM
gregorynp's Avatar
2022 GLS450
Could you break down the parts costs, all O E?
thanks
