SL/R230: Command System Replacement 2005 R230
Old Aug 8, 2019 | 05:37 PM
KennyK's Avatar
2005 SL500, 2016 SL550, 2014 Boxter S, 2018 CT6
I have a 2005 SL500 . The car is virtually perfect and has only 25K miles.
Unfortunately, the command unit screen is experiencing intermittent failures and I fear that I will need to replace my command system.
I am not interested in upgrading or any aftermarket options. I have researched several past posts and cannot find a clear answer as to how to acquire a new command unit. If that is possible, where would I get one and how much would it cost
Thanks in advance for any help that you can provide
Old Aug 9, 2019 | 02:33 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
fwiw: in case you start looking for a unit on the internet: search for Comand, with a single m. (The somewhat clumsy acronym stands for cockpit management and navigation device). Be very aware of typology (versions); leave it to the Benz Boys to conjure up a confusing numerical sequence of distinctly different Comand versions.
https://en.wikipedia.org/wiki/Comand_APS
Old Aug 9, 2019 | 08:18 AM
imtheking's Avatar
Former R230, W220 and W221 owner
Ebay?
This is a good site to- junk yards across the country-
car-part.com
Old Aug 10, 2019 | 11:30 AM
Ivan750's Avatar
Mercedes SL r230
What is the problem you are having? screen error or does it no longer work well?
Old Aug 10, 2019 | 03:57 PM
KennyK's Avatar
Intermittent screen freezing (stuck on MB logo). After a few minutes, it sometimes resets and things are ok for a few days. Lately, I also experienced some screen flickering.
The problem is getting more frequent
Old Aug 10, 2019 | 04:18 PM
Ivan750's Avatar
Mercedes SL r230
the fault does not seem to be the screen, I would say it is something more serious. My problem was that my screen lost color and there were spots of dead pixels, a computer workshop here in Spain changed the screen for another and everything was solved. Sorry I can not help but the symptoms suggest that it is something more complex. I hope you are lucky and you can repair it
Old Aug 12, 2019 | 03:25 PM
KennyK's Avatar
Update. Took the car to our local MB Independent Shop. They re-booted the system, and at least for now, all is fine
Best of all-No Charge
