SL/R230: COMMAND Video while driving
Old Sep 1, 2019 | 06:01 PM
ceberus's Avatar
SL 550
Curious if possible to watch DVDs while driving. It's not for me, but when on long trips it would great for my wife to be able to watch and to also key in a location to the navigator. I found video in motion website but 2009 SL 550 not supported. Any other options?
Old Sep 2, 2019 | 01:04 AM
Nosmo SL55's Avatar
2004 (MY05) SL55
I use the Mods-4-cars module.
http://www.mods4cars.com/sms/shop/in...ode=view&id=53
This allows me my passenger to watch digital TV & DVD whilst in motion on my MY2005 SL55. Works Great.
I note that the description says that it works on all R230 (MY 2001-2012)
Old Sep 6, 2019 | 09:13 PM
ceberus's Avatar
SL 550
Thanks I found this software based solution which I just purchased. I will post results --
https://www.dvdinmotion.com/mercedes-benz#order
Old Sep 7, 2019 | 05:50 AM
Ivan750's Avatar
Mercedes SL r230
can you tell how the experience went please
Old Sep 7, 2019 | 09:01 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Reportedly, a c. $300 Chinese-cloned Star Diagnosis can enable video-in-motion by way of its Developer mode.
Old Sep 7, 2019 | 05:54 PM
ceberus's Avatar
SL 550
Ivan it's easy. You just give them your VIN#, download 10 files to an SD card and then follow these instructions:
At this point you should have the SD card ready to use in the car. The actual installation will be very easy:
1) Start the car and after the radio unit will be operable, insert the SD card.
2) Wait ca. 2-3 minutes. There will be no change on the screen, that is normal.
3) Remove the SD card and check if the DVD plays while you drive the car.
Works great very happy with it!
Old Sep 8, 2019 | 10:44 AM
Ivan750's Avatar
Mercedes SL r230
Thanks for the explanation
Old Sep 9, 2019 | 03:51 PM
eatmycrackers's Avatar
2005 SL65 AMG, Motorcycle
Assuming "my friend" had access to one of these DAS machines, could you recommend the where that option would be in the navigation? I've looked before on "his" computer and could not find it.
Old Sep 10, 2019 | 09:34 AM
bobterry99's Avatar
Originally Posted by eatmycrackers
...could you recommend the where that option would be in the navigation?
My '03 cars can not play DVDs at all, so I don't know what setting you would change for your car. I'll emphasize that in my prior post I wrote "reportedly" this can be activated, and I should add that that comes from a web document describing some of the capabilities of Developer mode, and they were general and not specific to any particular chassis.
Old Sep 10, 2019 | 11:02 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Poking around in SDS with deverloper mode for COMAND NTG2, I found some settings that may be relevant. It looks like you can enable TV and DVD through them. I have not tried this, and don;t have a car to with NTG2 to experiment on, but it's what iI found:
http://benzbits.com/r230/COMAND_NTG2...daptations.pdf
