SL/R230: What tools in trunk ?
Old Sep 11, 2019 | 05:20 AM
starfighter's Avatar
r230
New to me 2005 sl500
What things should be in the trunk under the floor with the spare?
Thanx for any
Old Sep 11, 2019 | 08:08 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Thanx for any
Usually the pump for the tyre, wheel bolt spanner, jack, pliers, screwdriver from memory
Old Sep 11, 2019 | 08:13 AM
r230
Thanx
Old Sep 11, 2019 | 08:24 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Not much. An air compressor, bottle of fix-a-flat (almost worthless), White cotton gloves to protect your manicure. Lug wrench, I think there is a screwdriver and a tool to manually close the top. Spare tire if your car came with one.
I have added: a plug kit for plugging nail holes in tires. Jumper cables if I plan a long trip. A few spare relays, crank position sensor, wire, zip ties, pliers, screwdriver. You can’t carry tools for most ‘moderate or major’ repairs, so a cell phone and credit card cover the rest.
Old Sep 11, 2019 | 08:42 AM
r230
Very helpful. Thanx
Old Sep 11, 2019 | 02:11 PM
alk247's Avatar
2003 SL500
I added wheel mounting tool. Since our cars have lug bolts, there is no way to support a wheel in correct position to get them engaged. You can buy this tool, but I just bought long M14x1.5 bolt and cut the head off. It acts as a guide pin for the wheel.
Old Sep 11, 2019 | 02:16 PM
r230
Good tip.....
Thanx
Old Sep 11, 2019 | 02:38 PM
alk247's Avatar
2003 SL500
Important detail of the guide pin - provide some means of getting it out. You can easily screw it in by hand, but getting it out requires way more force. I drilled a hole at the top of the bolt to use Benz tool set screwdriver as a lever.
Old Sep 11, 2019 | 02:40 PM
r230
Thanx again
I may drill a hole or use double nuts if enough room
Old Sep 11, 2019 | 07:09 PM
Arizona Mike's Avatar
1988 560SL, 2017 SL 450, and a few Corvettes
I added wheel chocks and a cloth to kneel on when changing a tire.
Old Sep 11, 2019 | 07:16 PM
r230
Good idea Mike
Old Sep 12, 2019 | 05:52 AM
A1EK's Avatar
I've also got selection of Mercedes spanners too
Old Oct 16, 2019 | 08:36 PM
mike opalisky's Avatar
2007 sl 55 amg 2007 cls
tow bolt
Old Oct 16, 2019 | 10:13 PM
poppyboy's Avatar
2005 SL55 AMG
Brass hammer for my knock offs if I suffer a puncture on the Mulsanne Straight.
Old Oct 16, 2019 | 10:57 PM
tydriver's Avatar
SL550
My tool roll included an alloy lug guide... I didn't know what it was until I read this thread! It also had 2 Mercedes-branded wrenches (spanners), a screwdriver, and the gloves. I added a torx set, a nut driver that fits the under-engine cover screws, a LED light with a head strap, I may add a few items from above. Good stuff.
Old Oct 17, 2019 | 04:04 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
My tool kit included those mentioned above plus pliers, plastic drop-cloth, and a small bag of spare fuses and a puller. In USA, many insurers provide road-side service for a tire repair. Hopefully never happens, but that is the route I will try ahead of spare tire change-over.
Old Nov 16, 2019 | 09:33 AM
tydriver's Avatar
SL550
Last week I had the main ABC pressure hose from the pump fail. Bitterly cold and windy. At night. Fortunately it hosed down the front of the engine and serpentine belt, which promptly came off... saving the tandem pump. I was less than 5 miles from home on surface streets. I made it home by running up to speed, and when the coolant temps got too high, shifting into neutral and coasting as far as possible. Wait for it to cool down, and repeat. Hope the battery has enough charge to get me home. It did. $70 to fix the hose. $30 for a new belt, and all is well.
If I had been on a stretch of highway, I would have had to call for a tow.
It occurs to me that a good thing to have in the trunk would be a serpentine belt which is shorter, to bypass the ABC pump (and, I think, also the AC compressor). I think I'll research that a little. Does anyone know if the lug wrench fits the belt tensioner? I'll check that, too.
