SL/R230: voltage
Old Sep 22, 2019 | 09:49 PM
Austinsec's Avatar
Sl55 2003
voltage
Anyone know how to check what the voltage coming out of the alternator is.
I got the xentry system today with the car on my batt goes from 14v to 10 after some time. then i get votage error.
I bought a new regulator deciding weather to install or is it something else.
Old Sep 23, 2019 | 08:01 AM
ygmn's Avatar
2015 E400 Sedan
voltmeter
Old Sep 23, 2019 | 08:52 AM
mikefamig's Avatar
2005 R230 SL-500 / 2017 E300
Conet the + and - leads of your volt meter to the + and - posts of the battery, Have someone start the engine while you are watching the volt meter. the voltage should increase when the engine starts indicating that the alternator is charging the battery. If the voltage just decreases then your alternator is not charging the battery.
You might want to try this on another car that is working properly to see what it should look like.
Mike.
Old Sep 23, 2019 | 10:53 PM
Austinsec's Avatar
Sl55 2003
I know it is not charging the question is how do I know if it is the alternator or the regulator?
Old Sep 24, 2019 | 05:14 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
With engine off, the battery should read around 12.5V
With engine on, charging voltage should be around 14.1V regardless of load (lights, heater) the voltage regulator maintains the Volts by definition.
Just stick a multimeter on your rear battery and start the engine.
Old Sep 24, 2019 | 07:17 AM
Austinsec's Avatar
Sl55 2003
It does not maintain it keeps dropping until not enough to drive. How do I determine alternator or regulator?
Old Sep 24, 2019 | 09:20 AM
mikefamig's Avatar
In the old days of mechanical regulators you would just connect the field terminal of the alternator to ground which would send the alternator into full charging output increasing voltage at the battery. If grounding the field terminal does not raise voltage then the alternator has a problem. Even if you could find the field terminal on your R230 alternator I would hesitate to strap it to ground for fear of damaging a sensitive electronic component.
In any case the regulator is probably inside the alternator case so the alternator will need to be removed for repair.
This may help
https://mbworld.org/forums/sl-class-...lator-diy.html
Mike.
Old Sep 24, 2019 | 09:48 AM
Austinsec's Avatar
Sl55 2003
so I bit the bullet and attempted to replace the regulator. sadly the screws that hold the regulator 2 of the 3 are stuck and I am doing it under the car any advice?
Old Sep 24, 2019 | 10:06 AM
mikefamig's Avatar
Use a long handled wrench and instead of pulling on the wrench handle, rap the handle with a hammer. This will often break a stuck screw loose. Heating up the engine might also help.
I just did some reading online and I learned that the regulator has contact brushes that wear with time so it's a good idea to change it as a matter of course after 100k miles or so.
Mike.
Old Sep 24, 2019 | 10:41 AM
Austinsec's Avatar
Sl55 2003
the screws are philips got one more loose , last one is the one towards the top not way to reach with 2 hands for tapping
Old Sep 24, 2019 | 10:53 AM
mikefamig's Avatar
Worst case remove the alternator. It's better than damaging the alternator.
Old Sep 24, 2019 | 11:04 AM
mikefamig's Avatar
Do you have enough space to use a 1/4" drive ratchet wrench with a phillips head screwdriver tip?
Old Sep 24, 2019 | 12:35 PM
Austinsec's Avatar
Sl55 2003
yes but it seems srtipped Ill try again
Anyone on long island that is handy that can help switch regulator on alternator , I have bottom 2 screw out but the final one is stuck. Im on exit 39. thank you
Old Sep 25, 2019 | 11:06 AM
A1EK's Avatar
ratchet with Philips is a good idea, have you tried using a rubber band on the stripped head trick?
otherwise use an easyout tool
You may find once you have the regulator off, the brushes have just worn ?
Old Sep 25, 2019 | 11:31 AM
mikefamig's Avatar
If the alternator were on the workbench you could break the plastic body of the regulator exposing the screw shank so that you could use a vise griip pliers to remove it.
Mike.
EDIT - Also ii the alternator were on the bench I'll bet that you would be able to remove the screw with a screwdriver.
