SL/R230: Quad exhaust tail pipes modification
SL 350 R230 (3.7L with AMG Speedshift autobox)
Continuing my Exhaust modification theme, next week I will be getting trigger happy with my welder and removing the old ovals in place of two twin exhaust tail pipes to get the quad AMG look!😎
To squeeze them in I'll need to trim a few mm from the bumper, will post some before and after pics.
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I did quad conversion on my w204. Looks great.
Ours was just AMG diffuser swap; since you have to cut, make sure you do a clean job, no going back!
welded on
done, at gas station
three tube layers !
right side done.
left side done
Okay so quad pipes all done.
Removing the old tail pipes was the hardest part, really we solid, with 3 layers of tubes !? Had to grind and cut them off.
Then slight trim of the rear valance to
removing old trim
e the wider twin pipes then weld them in place.
Very happy, no change to exhaust note which is great, what do you think?
Speed750 (10-10-2019)
A1EK (10-11-2019)
danaw007 (10-12-2019)
to IVAN750
The quad pipes are offset, you need to cut the old ones off, then trim and weld on the two twin pipes each side. You will also have to trim a little of the rear valance too as they are wider.
The ones I bought are these ones:
https://www.ebay.co.uk/itm/Cartuner-...item4b6d3550c8
Ivan750 (11-19-2019)
