SL/R230: Red BAttery light - can it be caused by high voltage?
I've had the red light come on only once in the last few weeks and that was after repetitive engine on-off situation (short trips) and sitting on a parking lot with the engine off and the stereo running for 10 minutes.
My AGM battery is not covered by any warranty at this point, so eventually i will have to buy a new one.
I tested it with two different battery testers and they both showed "good battery" or "good battery - recharge".
Even when fully charged it always measures actual CCAs under the value listed on the label. Battery is rated at 760 CCA and it measures around 600-630 CCA.
The front battery, under the hood, (mercedes branded) tested "good battery" multiple times, even if the car sits for weeks.
