SL/R230: Red BAttery light - can it be caused by high voltage?
2003 SL55 with 135k miles.
Car runs great but for the last 3 weeks, every single time i start the engine, a red battery light pops on the dashboard.
I get code B1828 ...which points to Relay K57 being bad or "no circuit 61".
- I replaced the relay. It made no difference.
- I am not sure how to test "circuit 61" and there is no info on it in STAR. I am not even sure what/where is circuit 61
- Using a volt meter, i measured the voltage at both batteries at idle. Rear battery in trunk is at 14.25 volts ...... front battery is at 14.60-14.70 volts.
Are these voltage value normal? Isn't 14.60V a bit too high? Can this be the reason for my Red battery light, as soon as i start the car?
My alternator was replaced with a rebuilt Bosch unit about 20k miles ago. I am starting to wonder if the voltage regulator may be bad and causing the red light?
Btw, in the past, i used to get the red battery light from time to time. It would disappear on its own or after i reset the code. Now, it seems like it's been on consistently for week. It doesn't go away.
Any ideas?
Any ideas?
This is an AGM battery, purchased from Auto Zone or one of the big chain parts stores. It was installed in March of 2017, so it's 2.5 yrs old.
1. Does it make sense for it to be bad already?...given the age and the 11.9V reading?
2. Can red battery light on the dash be caused by this 'weak' battery? .... the error code points to bad relay or bad circuit 61. It does not mention anything about battery issue.
I can replace it (and i kind of hope the battery is the real issue)...but AGM batteries are not cheap, and if it turns out that it was not the reason for my red warning light...it will be *almost* wasted money.
I will plug my CTEK battery maintainer tonight so the battery is fully charged tomorrow and i will see if the red warning shows up again. This should be a good test.
Thank you!
Thank you!
Circuit 61 consists of a single wire from the alternator to the passenger SAM. You can view it's on/off status by viewing actual values of the passenger SAM.
Obviously the power supply control module runs a test of the K57 relay. Possibly it measures the current through the coil of K57, and your slightly-high voltage causes too much current and the test fails. But this is pure speculation.
I'd check two things: the status of Circuit 61, and from the power supply module (BNS) actual values I'd see what the voltage at terminal 30a is with the engine idling -- this is the voltage the BNS is measuring on the starter battery.
I would find the receipt and take it back asap. It probably has a 5 year warranty so you might get a new one free or at a heavily discounted rate. Even if you can't find the receipt I would return it. Sometimes the stores keep records , bar codes etc.
It's difficult to diagnose electronics if your not starting off with proper voltage.
That said, if the battery is initially at 10.5 volts and does not charge up fully after a long drive, then there likely is a problem with the battery.
At any rate, on no account will a discharged rear battery trigger a red warning message in the cluster or set fault code B1828. Needlessly replacing a good battery will contribute nothing to solving the problem at hand.
Later in the afternoon, i checked it again.....(car has not been driven) and the battery was showing 12.4 volts. I will check it tomorrow morning, and i expect it to be around 12 or a bit less, as it was 2 days ago.
I am not against getting a new, fresh AGM battery at some point (not cheap, but if necessary, i will do it), but based on what bobterry has shared, it's very unlikely that a new battery will solve the red light on my dash. Or is there ANY possibility that a weak rear battery can actually cause the red light? The error code certainly does NOT point to a battery issue.
Last winter, on a few occasions when the car was not driven for a week or more, i got a warning in the dash that consumer were offline.... and after 15min driving, everything came back on. It was a separate issue....related to discharged rear battery. Seems to be common with these cars when sitting parked for 1+ week.
More importantly, I was still getting the the red battery light from time to time.... but it was never as consistent as it is now. So i wonder.... what exactly changed, what component fully failed, that i have the red light on now with every start of the car?? Something progressively got worse, i just don't know what. Logically... it may be a battery getting worse with time, but again, the error code does not mention a battery issue.
Here are some stupid questions.... since bobterry suggested "viewing actual values of the passenger SAM" .... where is the passenger SAM located on the R230?
Also, should i monitor actual values with STAR or is there a better way to do it with a volt meter?
What values am i looking for... what is normal and what is not?
Frankly.... that 14.6V i see at the front battery with the car idling....bothers me. Perhaps a new voltage regulator is the right thing to start with....given a new Bosch unit is $40 or less.
Thanks!
While the charging voltage on the rear battery is constant, the average voltage on the starter battery varies. I spot-checked mine and measured 14.5 volts. It's my guess that 14.6 volts may not be abnormal; and if it is, the only detriment is a false B1828 code and fault indication in the cluster.
I've been doing a lot of reading and all documentations states that a RED battery light on the dash is usually related to some sort of starter/front battery issue. Since my battery seems to be healthy and i am seeing this "kind of" high voltage ... i am trying to pin point what else around the front battery may be wrong.
I am eliminating the rear/trunk battery from the suspected items.
Also ... based on the pdf document shared in this discussion, it sounds like the red light will not disappear on its own and it needs to be reset every time. In other words, now i am thinking, my issue may not be constant. It may be something that triggered the light 2 weeks ago, and since i have not reset it, it stays on every time i drive the car. Is this really the case or this red light should go away on its own, if the fault disappears?
Your test with Voltmeter, show that charging voltage of 14.25V at the rear battery is right, but the battery is not taking charge.
I suspect that you have a partly faulty rectifying bridge so that you are getting too much AC instead of DC to the battery.
Try set the Voltmeter to AC and measure voltage at idle. AC should not be more than 0.5V.
Don't lose sight of what the B1828 fault code is indicating.
Went in the garage and first thing i did was check the voltage at each battery. The car has been parked for almost 48hrs now. CTEK charger has been disconnected since yesterday morning.
This is what the voltmeter showed me:
Rear battery - 12.3V
Front battery - 12.7V
I started the car and surprise! .... NO Red light error. I turned engine off....started it 2-3 more times.....still NO Red battery light on the dash. Like it never happened!
At idle...
the front battery shows: 14.60-14.75V
the read battery shows: 14.22-14.25V
So, what changed that caused the Red warning light to go away?
The only thing i did in the last 48hrs was the CTEK connected overnight on Saturday to fully charge the rear battery. Before CTEK it was at 11.7V ....this morning it was at 12.3V.
Yet, we determined that the rear battery has nothing to do with the Red battery warning light. I am confused, to say the least.
Then i connected STAR to the car and checked some values.
The error code was still stored, even though i was not getting the dash light. I cleared the code.
The Pass-Side SAM shows the following values:
Terminal 30 - 14.3V
Terminal 61 - ON
Terminal 15 - 14.4V
The BNS module values are these:
Terminal 30 - 14.2V
Terminal 30a - 14.6V
I did a terminal 61 check and it passed, as expected. With engine OFF .... Term 61 should be OFF. With Engine ON.... Term 61 should be ON.
Any ideas, based on all of the above?
I realize that i now do NOT have the error light on my dash, so everything is expected to be in range. If i get the red light again... i would have to recheck these values again.
Something is 'acting' up for sure, i just can't pin point it.
At idle...
Terminal 30 - 14.3V
Terminal 61 - ON
Terminal 15 - 14.4V
Terminal 30 - 14.2V
You should continue to monitor the voltage of the aux battery. 12.3 is still marginal, but much better than the 11.93.
I would advise putting the CTEK back on it for up to 48 hours. Depending on the CTEK model you have, it should indicate that the battery is fully charged and the charger has entered the float mode. At that point, the voltage should be 13.6V. When you disconnect the CTEK, it should drop to around 13.0. If the CTEK can't get above 12.4 or so, the battery is bad. I really don't want to debate whether a bad aux battery can trigger this error. (If you recall, my position is that low voltage to the battery control module can raise spurious errors, but if you don't agree that's fine.) But, regardless of any other problem, If 48 hours on the CTEK doesn't reach float at 13.6 V, the battery is bad and should be replaced anyway.
Also, check that the cables are free of corrosion and tight. If the CTEK fully charges the battery with enough time (remember 13.6 V is the float level of an AGM battery) but it drop below 12.4 when the CTEK is removed, there is a charging problem. The fact that you see 14+V when the engine is on is a good sign, but doesn't eliminate a charging problem. You can have adequate charging voltage but not enough current (amps), due to any number of problems. But a wiring problem (a loose cable somewhere, for instance) is high on the list. You'd see adequate voltage but the high resistance of the loose or corroded connection will limit the current flow.
In summary, hang the CTEK on the rear battery again for up to 48 hours. If it gets to 13.6, disconnect the CTEK and monitor the voltage for a week. If it doesn't, you need to bite the bullet and replace the battery. Maybe not at Autozone?
It's apparent that your power supply module has an intermittent electrical problem or its electrical connector(s) are corroded. I'd check the connectors.
When you say "power supply module", are you referring to the BNS module in the trunk, where the K57 relay is plugged in?
I fully agree with you - the ONLY thing that changed in the last 48 hrs to trigger the red light going off....is the rear battery sitting on the CTEK for 12 hours.
I will plug the charger tonight and leave it connected for couple of days, just as you suggested. I will monitor the voltage levels and report back.
Thank you!
I'll revise my prior post suggesting the problem is at the power supply module to add that I suppose it could be the passenger SAM as well failing to register Circuit 61.
It's peculiar to me how two very different fault conditions -- a faulty K57, the alternator not charging -- are assigned a common code in the power supply module.
