SL/R230: no starter sounds
Shifter shows P or N when moved, foot on brake, key or keyless, starter does nothing.
Disconnected both batteries & after 1 minute reconnected no change. I'm out of ideas...
Exact same symptoms last Friday, starter was toast
I'd first discern whether or not the starter relay is energizing when the ignition key is turned. The starter relay is among several relays in the passenger-side fuse box. You can tell if it is energizing by listening for an audible "click".
If the relay is energizing, next I would check the voltage on the starter motor; if it isn't, then I would check the I'd first discern whether or not the starter relay is energizing when the ignition key is turned. The starter relay is among several relays in the passenger-side fuse box. You can tell if it is energizing by listening for an audible "click".
If the relay is energizing, next I would check the voltage on the starter motor; if it isn't, then I would suspect the ignition switch and investigate further with Star Diagnosis.
