SL/R230: R230 top hydraulic pump reservoir location.. fill opening..?
Old Nov 7, 2019 | 02:59 AM
bill morrow's Avatar
'04 E500 4matic, '06 SL55, Cadillacs: '59 Convertible, '70 ElDorado, 3 '95 Buick Roadmaster Wagons
my front lock cylinder is leaking..
to replace it i have to get the front part of the top up far enough to R&R it..
to do that i need to add oil to the pump..
does anyone know where to fill the top hydraulic pump reservoir.. ?
i can see the pump and reservoir but see nothing other than what looks to be a small allen head steel plug in the steel block of the pump assembly..
Old Nov 7, 2019 | 04:46 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
MB uses an injection tool, in one of the allen ports. I burned a small hole in the plastic container and used a conventional injector with a tube to suck out and renew the hydraulic fluid. Don’t drill, as debris might contaminate the delicate system.
Old Nov 7, 2019 | 01:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
https://benzbits.com/R230/Roof/Fluid...rlyVersion.pdf
or
https://benzbits.com/R230/Roof/FluidLevelRevised.pdf
Old Nov 23, 2019 | 01:09 AM
thanks for the links to the star system info..
special oil..?
can't use the CHF 11S..?
EDIT: found the oil on amazon with a chrysler label..
Genuine Chrysler Accessories 68035321AA Aral Vitamol ZH-M Hydraulic Fluid - 1 Quart
Amazon Amazon
anyone know where i can get the "tool" to add the hydraulic oil to the system..?
Old Nov 23, 2019 | 04:36 AM
Hydraulic fluid ZH-M, used and sold by MB, is no big expense in the quantity you need.
Old Nov 28, 2019 | 04:44 AM
got the hydraulic oil..
now to get it into the pump reservoir..
will any of these tools i found on amazon do the job..?
1.
Amazon Amazon
or
2.
Amazon Amazon
or
3.
Amazon Amazon
i know they all look alike and they might be but will any of these fit the treaded opening in the top hydraulic pump reservoir.. ?
they all say 11mm diameter of the threaded end..
thanks
Old Dec 2, 2019 | 09:13 AM
FxFormat's Avatar
SL 600
That pump looks way different than the one in my 2005 SL, it looks like the one in my 2009 SL, i dont see a port to fill it. Might have to melt a hole in your reservoir and fill it through there, it's not pressurized or anything so it'll be fine. You can just duct tape it back after you fill it.
Old Jan 31, 2022 | 10:55 PM
Extreme54's Avatar
From: Charlotte, North Carolina and Clarkston, Michigan
SL550
2009 SL550 hydraulic roof pump reservoir.
I found a plug on the read of the reservoir. The allen wrench which fits the plug on top of the pump, fits the reservoir plug. I used a bottle long nose to fill the reservoir. The reservoir is not pressurized. I filled the reservoir to the marks on the side of the reservoir. My trunk opened, the hard top came back up. I will have to top off the reservoir again but, the hydraulic pump works again and no need to go to the dealer. Oh, currently the dealer and second party repair shops are backed up…two weeks.
Old Feb 24, 2022 | 01:27 PM
Tomcat SL's Avatar
2004 SL55 AMG
Is this the "fill port"?
Old Feb 24, 2022 | 02:01 PM
Tomcat SL's Avatar
2004 SL55 AMG
I also found a "port" in the center of the front round end of the plastic cylinder/reservoir that might be the fill port? yes/no?
Old Feb 25, 2022 | 03:39 AM
Yes
Old Feb 25, 2022 | 07:36 AM
Tomcat SL's Avatar
2004 SL55 AMG
Originally Posted by Frederick NL
Yes
So do you loosen and tilt it a little.
It sure seems like an easy fill compared to syringes, etc...
Old Feb 25, 2022 | 07:40 AM
Yes, that is how it's done. If I remember correctly, the filling port is also the level.
Old Feb 25, 2022 | 10:17 AM
Tomcat SL's Avatar
2004 SL55 AMG
Thanks! And yes, the fill is at the level mark.
