SL/R230: Coilover time
Old Dec 12, 2019 | 06:57 PM
Blazeracer's Avatar
2003 SL500
Coilover time
ABC pump took a big dump today... Zero pressure, car is on the ground. Time to go with coilovers so we can road trip this car without having to worry about needing a tow for the suspension ever again. I keep telling the Mrs we should have gotten a Corvette. These old ones are a headache, but damn, when is runs, it runs good. New ABC pump is $1,300 and there are still plenty of more parts to fail. Strutmaster kit is $1593.31 shipped and never have to worry about it again. I have a neighbor with an SL.. He had a shop put a Strutmaster kit on his and swears by it.
Who's done a Strutmaster kit in the driveway??
Old Dec 12, 2019 | 07:03 PM
Blazeracer's Avatar
2003 SL500
What about the kit from Ceika? Does anyone have that kit on their car? I'm think Strutmaster is going to be the better option since it's what they do..
Old Dec 12, 2019 | 07:08 PM
H Swint's Avatar
SL55 AMG
Strutmaster's are extremely over priced and have zero adjustability compared to the competition. Go with BC or Ceika but just remember, none of these options come with sway bars or power steering conversions.
Old Jul 9, 2025 | 02:10 PM
Ajai Thomas's Avatar
2006 SL55 AMG
Silver's Neomax and VVK front and rear sway bars. I was there when one of my mechanics installed CEIKA and he and the car's owner would not installed CEIKA again if they did it from start. i strutmasters are not the way to go if you want real adjustability and handling.
Old Jul 10, 2025 | 09:15 AM
imtheking's Avatar
Former R230, W220 and W221 owner
I had Strutmasters on mine and the ride quality and noise was so bad that I went BACK to abc. Please please please please stay away from strutmasters. So many better options out there.
Neomax has a lot of good reviews and Brandon who lives in Ohio has been installing them for customers for a long time now. He's a good guy and will answer all your questions. People from all over the country are shipping their SL's to him to get Neomax installed. If I ever decide to purchase an SL again, the first I will do is ship it to him to get rid of ABC.
Check out his youtube and hit him up. He's installed hundreds of these by now. he really knows the ends and outs of this car and will install and adjust the new coilovers properly.
https://www.youtube.com/@goldelementautoworks
Old Jul 10, 2025 | 09:32 AM
2006 SL55 AMG
Brandon is a legit dude. i believe this is his side gig and he is or may be a first responder by day.
Old Jul 10, 2025 | 01:09 PM
imtheking's Avatar
Yea- he knows Mercedes very well. He's built a good reputation. He even has videos installing coilovers in case you want to do it yourself.
He removes the entire ABC system from your car. Pump, lines etc....customers from what I see and hear have been very happy.
Old Jul 11, 2025 | 07:22 AM
Don Butts's Avatar
2006 SL55 2007 ML320
I did mine in my driveway. Pretty straight forward. I didn't go hard at it and took about 6 hours. Getting the old strut bottom out of arm was tough. I went with strutmaster. The car does not handle corners as well and it's much softer and smoother ride. I don't drive mine hard around corners, just love to launch it. I could use sway bars. But very happy with the confidence my wife and I have to drive it now without worry.
Old Jul 11, 2025 | 09:21 PM
Gene Fiorot's Avatar
SL500
Strutmasters are not noisy. I don't need adjustments but just calibrated to the SL500. And A front sway bar makes any handling issues moot.
Old Jul 21, 2025 | 04:29 PM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
We have a Corvette & still appreciate the SL
now that it has Coilovers & VVK sway bars.
Couple positives not mentioned ditching the ABC are 100-125 lb weight loss, mostly off the front end and the power bump from an AMG PS pump swap over the parasitic draw of the ABC pump
The front end lift? I don’t miss it. It’s not a problem Our car is lowered on 20’s and doesn’t bottom out on large speedbumps
Old Jul 22, 2025 | 03:15 PM
HLG600's Avatar
2009 SL63 AMG
What were the issues with the CEIKA setup?
Old Jul 23, 2025 | 02:05 PM
2006 SL55 AMG
the ride quality wasn't there according to my buddy who first installed it on his. that's why i went with Silver's neomax because he did all the research and i just learn from his experiences.
Old Jul 23, 2025 | 02:07 PM
2006 SL55 AMG
how do you like the handling with the VVK sway bars and was it an easy install? (since the VVK sway bars were fabricated using a SL55 r230)
what coilover did you use?
Old Jul 24, 2025 | 01:08 PM
I went with Silver's Neo Max coilovers which went on without any trouble. Quality is a little better than a BC of comparable prices.
The upper mounts are engineered to a higher level, specifically on this application. Not to say that the BC's might function just as well
I have BC's on our 86. I've never seen Ceika in person or used them
Nobody mentioned you will need to cut a hole in the trunk carpeting unless you feel like dismantling the best part of the the entire trunk enclosure for mounting and each time you want set the adjusters on the rear
Regardless of the brand.
I found automotive carpeting the was a solid match and now I can remove my foam backed patch whenever needed. You can't even tell it's there.
VVK bars are really nice. The mounts are CNC'd Billet. No noise, just solid fit and work very well.
You have to use an engine support and drop the front subframe to get the bar in place and the rear must be lowered also.
Old Jul 24, 2025 | 01:44 PM
2006 SL55 AMG
One thing i did opt for is the SWIFT spring upgrade on the Silver's Neomax. That install will be the next project. I'm going to remove the hydraulic lines and all the ABC hardware, do it right instead of a half assed install job and have the ABC weight still in the car.
Old Aug 14, 2025 | 01:19 AM
dsrosey2's Avatar
SL500
Cool strutmaster
We did ours in our own shop. Not a huge deal. But the ride sucks. Tech told me to drive it for a few hundred miles so the springs could settle in. It sat for a month before it came out of the shop so I disagreed, but have driven it anyway. No improvement. Tomorrow I will call again, but since there is no adjustment, I do not think anything can be changed? Can anyone give some advice?
Old Aug 14, 2025 | 09:03 AM
imtheking's Avatar
strutmaster?
Old Aug 18, 2025 | 01:58 AM
"We did ours in our own shop, Tech told me to drive it so the springs can settle in" ???
Huge red flags. ^^
If you are part of this shop you should've been aware that setup is the crudest/cheapest possible suspension available. You did although got what you paid for. A low cost, entry level shock designed only to facilitate a dead suspension removal with no adjustment and a considerably short lifespan.
Whoever the "tech" was also knew it was not up to the chassis level standards but I'm sure his thoughts were; WTH it got the car at least somewhat drivable and out of the shop.
I don't envy You, having the uneasy choice of driving a < enjoyable Mercedes or putting the suspension right (removing the pogo sticks and re install decent coilers/sway bars) to enjoy a sussed out car; Or selling it and let someone else pogo down the road
Good Luck whichever way you go
Old Aug 27, 2025 | 10:08 PM
dsrosey2's Avatar
SL500
HOPEFULLY YOU WILL OFFER THE LINES TO THOSE OF SUCKERS WHO ARE OPTING TO RESTORE THE ABC. FEW PEOPLE SAVE THEM. I HAVE ALREADY CHANGED ONE.
Old Aug 27, 2025 | 11:14 PM
SL500
You gotta love a Purist!
Old Aug 29, 2025 | 03:26 PM
JoBlow's Avatar
06 SL500
Reusing 20 year old rubber part that is subject to 3000 psi doesn't seem worth the risk.
Old Aug 29, 2025 | 03:28 PM
JoBlow's Avatar
06 SL500
When 9X% of them have converted to struts the still functioning original ABC cars are going to be worth a lot more. JMO
Old Aug 29, 2025 | 03:41 PM
SL500
That is an interesting prediction which I don't see happening. When I purchased my 2004 Sl500 I was thrilled knowing I didn't have to spend 2 grand on top of the price of the car to make it a safe reliable car without worries of a collapse on the interstate. Let's face it the car has a terrible reputation with that ABC Suspension. .
Old Aug 31, 2025 | 01:49 PM
cdk4219's Avatar
95 SL600
you picked the wrong car for investment purposes, the only SL cars worth anything after the 60s are low mileage cars. The rest aren’t worth much
Old Sep 2, 2025 | 11:42 AM
JoBlow's Avatar
06 SL500
