SL/R230: Looking for Tips in Buying a used SL 500
Old Dec 14, 2019 | 11:59 AM
Cardinal Flyer's Avatar
2005 SL 500
Hi All!
New to the Forum (this is 1st post) so forgive my Noobishness!
Looking to buy my wife her dream car, an SL 500 preferably Red (any color BUT Black or Silver).
Trying to spend no more than $22K. Searches are turning up cars from 2003 to 2012, with the mileage ranging from 45K on an '03 to 59K on a 2012.
Read the Buying Guide post on this forum which helped ID mechanical systems to check, without regard to year. But I'm wondering if the accumulated wisdom has identified any particular years as troublesome and worth avoiding. (For example, in the Corvette World, 2013 427s are notorious for valve guide failures, 2001s often have issues with poorly seated rings and original 1968s have many "new model" issues)
Thanks in advance for your comments!
Bill Bloyer
Old Dec 14, 2019 | 12:20 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
2003 may be the best year for the SL500, since this is the only year which has the robust 5-speed automatic transmission. 2007 SL550s have an issue with an idler gear that wears out prematurely. Rodney ("Rudeney") has written about this in detail and cited the exact range of VINs affected.
I suggest test driving an SL55. All years are probably more or less equal.
Old Dec 14, 2019 | 04:51 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
The lady might prefer the smoothness of an SL500 over the overall stiffer SL55. (Confession: I never drove an SL55).
Old Dec 14, 2019 | 07:57 PM
bobterry99's Avatar
I own both models and can discern no difference in the ride quality. That said, the '55 has different struts and possibly software as well, so it should be different in some way.
Old Dec 15, 2019 | 12:38 PM
Two reds to choose from.. one of the cars is mine, the 1:43, unfortunately (but then I own a black one).
Old Dec 15, 2019 | 02:40 PM
2005 SL 500
Two reds to choose from.. one of the cars is mine. The 1:43, unfortunately (but then I own a black one).
Ours is the red in the middle picture. Do you know what the "official" MB name for that color is?
Thanks!
Old Dec 15, 2019 | 03:06 PM
2005 SL 500
Thanks!
Old Dec 15, 2019 | 03:14 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Use this website to get your data card info:
https://lastvin.com
Old Dec 15, 2019 | 04:24 PM
Here’s19 pages with apparently existing MB colors (includes chassis coating colors). And it fails my Obsidian Black...
https://nsk.mercedes-benz-clubs.com/...kleurcodes.pdf
Old Dec 15, 2019 | 04:36 PM
bobterry99's Avatar
To me that appears to be a color marketed in the U.S. as "Magma Red". The bottom picture looks like "Mars Red", and the top looks like "Firemist Red".
Old Dec 15, 2019 | 05:16 PM
2005 SL 500
Another NOOBIE mistake, didn't get the dealer to throw in a German-English Dictionary
According to the VIN Decoder, Thanks Rudeney!, it's called "Fire Opal Red"........
Old Dec 16, 2019 | 02:21 AM
Maisto Red, Sir.
Old Dec 16, 2019 | 11:40 AM
bobterry99's Avatar
Standard red colors for U.S. SL500s were limited to Mars Red, Magma Red, and Firemist Red.
Old Dec 16, 2019 | 01:55 PM
The car you were referring to is a toy, Maisto 1:43. Gets me through the winter while big bro has to stay inside. Now don’t tell me you knew this all along .
Old Dec 16, 2019 | 02:04 PM
bobterry99's Avatar
Whether it is a toy or an apple is immaterial. If a U.S. SL500 is similar in color and non-metallic, then it is probably Mars Red.
I have two Maisto cars. One appears identical to the car you show, though if yours is c. 9" long like mine, the scale is 1/18 -- not 1/43. My other toy is color "Orion Blue" and has the roof closed.
Old Dec 16, 2019 | 02:12 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Would skip the 500 and go to the 55/600/65. The ABC is the cars most maintenance needy area of the SL so, at least, go with a SL with a good engine.
Old Dec 16, 2019 | 02:28 PM
Leej's Avatar
2008 SL550 R230, 2004 E320 W211
@Cardinal Flyer I'm certainly no expert, but I have an 2008 SL550 and experience with the "normal" issues with the R230. I'm sure there are some significant differences between the years (i.e. 5 speed transmission vs 7 speed, and idler gear as mentioned by BobTerry and others), but it is my opinion that these differences wouldn't greatly impact my decision on a particular year being bad or a year to avoid... It is my opinion that the critical issues with these cars are not necessarily dependent on a certain model years, but whether or not those "normal" issues have been addressed in that particular car.
The point is that I would look for an R230 that is in the mileage range and age/condition that you want, with the options/colors and engine (500/55/600/65) you want, and a price that you are willing to pay. BUT, more importantly, be aware and prepared for the potential "normal" issues:
  • ABC system (leaks, accumulators/dampeners, pump, etc.)
  • SBC system (hopefully warranty?)
  • motor mounts (they can just fail with age)
  • vario roof issues (noises, hydraulic leaks, flaps, other failures, etc.)
  • camshaft magnets and sensors (easily replaced for not too much $$$)
I'm sure there are other common issues, but this is a short list.
Hope this helps.
Lee
Old Dec 17, 2019 | 11:39 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MBZ uses two names for their colors. One is the "marketing name" and the other is the internal name. The marketing name for "Fire Opal Red" is "Mars Red", color code 590. Note that there have been a lot of problems with failure of Mars Red paint - search the web and you will find lots of unhappy owners.
Old Dec 17, 2019 | 02:39 PM
2005 SL 500
Thanks for the info Rudeney!
This Noobie was beginning to wonder if there were any valid sources for facts on these cars.
I can't see any evidence of a re-paint on the SL 500 we bought, and doesn't appear to have faded at all. 1-owner, low miles, and looks like it was always garaged so all I can do is hope I won't have problems, at least for a long time!
Old Dec 17, 2019 | 03:54 PM
My daily driver is a red VW Passat. The red has a tendency to fade in intense sunlight. Regular waxing (in a car wash) seems to preserve the colour well. And, at least in my country, a professional polish treatment is cheap. Result: bling bling.
Old Dec 17, 2019 | 06:12 PM
alk247's Avatar
2003 SL500
Define "cheap".
Old Dec 18, 2019 | 05:29 AM
Yes Sir!
less than € 100
Old Dec 19, 2019 | 10:29 AM
themotts's Avatar
2017 S63, 2003 SL500, 2010 S550, 2008 GL 450
i just bought this year a 2003 sl500 firemist red, with 28000 miles on it... only reason i buy a certain Mercedes is the service history, this car was a garage queen and has never seen snow or rain always look at the history.. (one owner factory dealer maintained) there are still unicorns hiding out there if you can find one that was driven 1500 - 2000 miles a year to the country club you will have years of fun, if it still smells new and you can do the maintenance its a incredible car, plenty of power and a great roadster... take your time an do the research
Old Dec 19, 2019 | 12:53 PM
picture(s) or it didn’t happen!
Old Dec 27, 2019 | 05:25 PM
JamesMitchell's Avatar
Veteran: Navy
'07 S65 '05 SL65 '07 GL450 '03 SL55 (sold)
Cardinal Flyer - Hello. I just posted a thread on some thoughts I went through in buying an SL. https://mbworld.org/forums/sl-class-...ml#post7937344
Happy SL Hunting!
