SL/R230: How to raise the wiper arms
Old Jan 19, 2020 | 03:49 PM
sivikvtec's Avatar
2005 SL65 AMG
So I might be an idiot, but......
How do you raise the wiper arms without hitting the hood?
Old Jan 19, 2020 | 04:02 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
If I remember correctly, you switch off the ignition when the wipers are ‘standing up’.
Old Jan 25, 2020 | 08:37 PM
TravisG's Avatar
SL550
thank you !
Old Jan 26, 2020 | 01:20 PM
sivikvtec's Avatar
2005 SL65 AMG
What a dumb design.
On my Lexus, you grab the wiper and force it up the windshield slightly, it clicks into a service position and the wiper clears the hood at that point.
Old Jan 26, 2020 | 03:03 PM
On VW, you hit the stalk after switching off the ingnition and presto - the wipers arms position themselves in service position (and why this print is in bold, heaven knows).
Old Jan 26, 2020 | 04:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by sivikvtec
What a dumb design.
Eventually, the plastic piece used to click and hold the blades in place will wear or break and then you'll be left with floppy wipers. To me, that is a dumber design.
Old Jan 26, 2020 | 05:00 PM
sivikvtec's Avatar
2005 SL65 AMG
ahhhhh my friend, you have obviously been conditioned by years of German car ownership.
Its a Lexus. My old one was 15 when I traded it with 185k miles and the mechanism worked fine.
Current one is 7 or so and also just fine....
Old Jan 27, 2020 | 12:05 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I've had the (dis)pleasure of owning and working on many Toyotas. Ive worked on many cars from many makes and MBZ by far seems to make the most sense to me. Not everything they do is wonderful, but overall, I find it better than anything else.
Old Jan 30, 2020 | 10:54 AM
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
No problem swappin wipers when they are in the parked position either but you have to be careful not to scratch the hood..
But i have to admit that i have not thought of switching the wipers on and turn off the ignition while the wipers is in the straight up position, That must for sure be the best way to swap wiper blades.
But here in Europe you can not get the SL class wiper blades anymore but you get from the E class which does not look good
So i just bought long enough cheap wiper blades and took off the wiper rubber and thead them into the old wiper blade holders. Looks much better than the large fasteners used on the E class
You can get Bosch wipers that look like the original wipers with the smaller fasteners that was used on the SL, R230. The identical wipers are: Bosch AeroTwin nr A 948 S
Old Jan 30, 2020 | 02:13 PM
The AeroTwins look good and they are perfect wipers.
