SL/R230: BeckwithR
Old Jan 31, 2020 | 03:51 PM
beckwithR's Avatar
W140 & W220
BeckwithR
Can anyone direct me to video that shows how to remove and replace the front valve block on a 04 SL 600 V12?
Old Jan 31, 2020 | 04:25 PM
SLcharge's Avatar
09 SL500, 03 E320 CDI Wagon
These videos are similar to what to on your car.
Old Jan 31, 2020 | 10:51 PM
beckwithR's Avatar
W140 & W220
I appreciate the response, however I was looking for a video that shows the valve block being removed from the car. I am aware of how to utilize the rebuild kit.
Old Feb 1, 2020 | 12:51 PM
sivikvtec's Avatar
2005 SL65 AMG
You really should purchase a WIS copy off eBay. Just be warned, it takes up a huge amount of hard drive space..like 40gb or something.
Old Feb 1, 2020 | 01:06 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
A member wrote that many (all?) the WIS on eBay run under a virtual machine player. I'd try to find a version that doesn't. It will require a software key, but those are readily attainable. If you find such a copy, send me a PM. I want a copy for myself and could answer any questions you have about installation.
Old Feb 1, 2020 | 06:08 PM
beckwithR's Avatar
W140 & W220
ABC
[QUOTE=sivikvtec;7969410]You really should purchase a WIS copy off eBay. Just be warned, it takes
I will look for this and let people know if I find it.
Old Feb 1, 2020 | 06:22 PM
sivikvtec's Avatar
2005 SL65 AMG
This is the one I bought. Took forever to download but worked fine thereafter.
https://www.ebay.com/itm/NEW-2019-Me...wAAOSw4apbRzO0
Old Feb 1, 2020 | 06:59 PM
beckwithR's Avatar
W140 & W220
So it might be a good idea to purchase a separate laptop just for the purpose of downloading information like this or I guess I could get some flash drives. I have definitely come to understand the benefit of having detailed information, specifically for the automobile you are working on. Thanks
Old Feb 1, 2020 | 07:48 PM
sivikvtec's Avatar
2005 SL65 AMG
You are correct. When I first got the car, I started out with just getting WIS from that eBay seller and loading it on my existing laptop. A few months afterwards I decided to get a SDS/DAS/Xentry system.
The laptop used for these systems already has WIS loaded onto it, so now I have two different computers with WIS.
There are some pretty heated opinions about what to buy and where to get it from. Just for your information I bought my laptop from this same eBay seller and it seems to be working fine.
I would just ask the seller to verify it has a SSD, not a HDD if you are interested. Mine did.
https://www.ebay.com/itm/Xentry-DAS-...EAAOSwcBpeGmCe
Old Feb 2, 2020 | 12:47 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
All I use now are SSDs. The Dell D630 I use in the garage for my cars has 8GB of RAM and an SSD and runs the VMWare virtualized version of SDS very well. I also keep that same virtualized copy on my Lenovo Yoga and two desktop PCs. They never connect to the car - I just have those to use for research. Again, everything runs just fine and fast, especially with an SSD.
Regardless of using a PC for SDS, if you have an older computer still using a mechanical hard drive, you can breath new life into it by installing an SSD and maxing out the RAM with at least 8GB.
Old Feb 16, 2020 | 02:23 PM
beckwithR's Avatar
W140 & W220
I had hoped when I finally responded I would have a more positive response However I rebuilt the valve block and put it back on the car. Now I am getting an ABC Messg. and no response from the system. The drivers side is up in the air and the passenger side is on the tires and no response from the system. This may be a stupid question, but any port in a storm. Is it possible that the electrical connections to the block could be on in correctly, wouild that create this issue?
Old Feb 17, 2020 | 12:35 AM
sivikvtec's Avatar
2005 SL65 AMG
The plugs are color coded. There is colored tape on the cable that matches the colored dot on the valve block.
Old Feb 17, 2020 | 01:44 AM
beckwithR's Avatar
W140 & W220
That doesn't seem to be the case with mine. I don't get any reaction when I press the ABC button on the console. The ABC indicator light comes on. Initially nothing happened, I started the car again and the left side went up and the entire right side stayed down. My confusion is, is that I thought the front and back had separate controls. Now nothing happens when I press the button. So are you saying that those electric connections on the block might create this issue? After all of your help you're probably thinking about sending me a bill. Thanks
Old Feb 17, 2020 | 02:03 AM
sivikvtec's Avatar
2005 SL65 AMG
You’re correct about separate controls for front/rear. I honestly have no idea if the rear valve block would malfunction because of an incorrect connection in the front valve block. This might be really hard to figure out without SDS.
Did you double check your plugs were in the correct sockets? There is a colored dot on the socket that matches the color of the tape on the cable.
Are your lines connected to the correct places? Here’s a pic from my car, I actually removed both front and rear valve blocks today so I can send them out to get rebuilt.
Old Feb 17, 2020 | 08:16 AM
bobterry99's Avatar
When the system acts in a peculiar manner I think you have to question whether the ABC computer is receiving bad data from its inputs, or the inputs are good but the computer has lost control of the valve blocks. The easiest way I can think of to resolve which is the case is to take manual control over the valve blocks and see if the struts respond correctly. Naturally Star Diagnosis can do this. One could use a lesser device and observe the sensor inputs, but drawing a conclusion might be a challenge that way.
Old Feb 17, 2020 | 08:17 AM
beckwithR's Avatar
W140 & W220
Valve block
I don’t seem to have those colored dots. Are you saying that this would cause the system not to respond if they are not correct?
Old Feb 17, 2020 | 12:01 PM
sivikvtec's Avatar
2005 SL65 AMG
Some people have reported strange behavior like that when they connected the plugs to the wrong sockets.
I would be shocked if you don’t have the dots, here’s a pic of mine, see the green and blue?
Old Feb 18, 2020 | 01:52 AM
beckwithR's Avatar
W140 & W220
Valve block
You sent me a link guiding me to the SDS, could you send it to me again.
Old Feb 18, 2020 | 08:15 AM
sivikvtec's Avatar
2005 SL65 AMG
Copied from my post in another thread:
I bought this multiplexer
https://m.aliexpress.com/item/327510...df8bfce&is_c=N
I bought the laptop and software from the seller below on eBay. I read some opinions online that the 9/2014 version of the software was the best because later versions had some functionality restricted, no idea if it’s true. I also wanted to be sure to get developer mode.
and this battery off Amazon
https://www.amazon.com/gp/aw/d/B01323CST2?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B01323CST2?psc=1&ref=ppx_pop_mob_b_asin_title
So I’m at around $400 all in.
Old Feb 18, 2020 | 11:33 AM
bobterry99's Avatar
On *******.com I have read that the 9/2014 version is the last which works with a C3 multiplexer. But that isn't true. I have the notion that what distinguishes the 9/2014 version is that it is the last for which the C3 will work with all or nearly all of the vehicles available for diagnosis. I believe that the latest version of Star Diagnosis will work with a C3, but there will be many c. 2015 and newer vehicles with which it can not communicate.
Old Feb 20, 2020 | 03:43 AM
beckwithR's Avatar
W140 & W220
I have been on the highway the last few days, I took a trip in my 98 SL 500 to remind myself of the pleasure and enjoyment you get when they are performing as they are supposed to. I came home and checked the connections, they seem to be correct. Still no change. I want to purchase the tools that you suggested and I want to make sure I am buying the correct things. I had no idea what a multiplexer was or it's function, so I looked it up. Based on the conversations on this forum and the fact that you have one I am thinking I should have one too. So should I be purchasing both the XENTRY software and the multiplexer?
Old Feb 20, 2020 | 03:45 AM
beckwithR's Avatar
W140 & W220
How do I access it?
Old Feb 20, 2020 | 07:29 AM
bobterry99's Avatar
You can get the multiplexer and cables from alixpress.com for $200. Sivikvtec just made a purchase a few weeks ago is happy with it. He posted a link that you should be able to find quickly.
As far as software, you can get it from me for free. But the Chinese bundle the software with the multiplexer for just $50 more, and that may be worth a go. I don't like that their software runs under a virtual machine, because that slows things down. That can be compensated by running the software on an SSD and be quite satisfactory, but there remains the fact that all things being equal, software runs slower under a virtual machine
If you want my software, you'll need a hard drive of about 80 GB capacity. You'll also need Windows XP, and that can be downloaded for free from Softlay.net.
Old Feb 20, 2020 | 07:41 AM
bobterry99's Avatar
A better idea than that may be to pay someone on eBay to install the latest software remotely via Teamviewer for $100. I presume what you received wouldn't run under a virtual machine. Maybe it's best to try the free software, and if you are less than satisfied, choose another option
Old Feb 23, 2020 | 10:33 PM
beckwithR's Avatar
W140 & W220
Direct me as to how I can download the software.
