SL/R230: ABC Malfunction -pls help
Old Feb 15, 2020 | 12:07 AM
alexisvx's Avatar
2009 SL550
Hi all,
While driving back home from work, the ABC malfunction light came up (white color). As a brand new owner of a 2009 model, I of course freaked out when I started reading online and on the forums that ABC problems can cost anywhere from $1,000 to $5,000.
I went back to my home parking spot and saw no leaks. Also, when I turned the engine back on, the error was gone. I put the car in drive (without driving) and still no error. I then pressed on the button that lifts the car up and down and everything seemed to work fine, the car lifted and lowered a few times with no weird noises and no leaks. Another thing I wanted to mention is that occasionally this past week when I went on speed bumps the orange triangle would come up for a few milliseconds not even long enough for me to see which sign it was.
I took the car to my mechanic who ran a diagnostic 2 days ago and no error came up. The diagnostic was done before the error came up today.
What do you advice me to do? What do you think this could be?
Thank you.
Old Feb 15, 2020 | 01:39 AM
sivikvtec's Avatar
2005 SL65 AMG
you either need to find a mechanic with a star diagnostic tool or you need to buy your own.
If you are unwilling or unable to do either of these things, your only option will be to start blindly replacing parts and pray the issue is fixed. Which is totally stupid, but the choice is yours.
ps, it’s probably just an accumulator.
Old Feb 15, 2020 | 02:23 AM
alexisvx's Avatar
2009 SL550
I am going first thing tomorrow morning to a mechanic. I just pray that it's nothing serious. I was confused by the fact that the message disappeared.
Old Feb 15, 2020 | 03:53 AM
Aussiesuede's Avatar
SL500 & GL450
Good chance that it'll be a need to replace one of your accumulators, or the pulsation dampner. All 3 are about $400 in parts and it's a good idea to just go ahead and replace all 3 together since they have about the same service life.The fact that you are not losing any fluid is a welcomed
event.
Old Feb 15, 2020 | 08:55 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
As two members have already mentioned, your problem is certainly an accumulator. It isn't a serious problem at all, and that is why the message you saw is in white and also why no faults were stored in the ABC controller memory.
An accumulator costs c. $130 online. I'll guess it takes 90 minutes to replace one, though I'm certain someone has completed the task much faster than that.
Finally, unless your mechanic runs diagnostic scans for free, consider buying something to do that yourself. For $130 you can have a hand-held Foxwell NT510 Elite, or for around $250 you could have Mercedes' proprietary Star Diagnosis System used by its dealer techs.
Old Feb 15, 2020 | 02:06 PM
alexisvx's Avatar
2009 SL550
So I checked my fluid levels and they were very low.
I took the car to a mechanic this morning and they ran a diagnostic. There was only a low pressure warning which disappeared on it's own when he filled up the fluids (it needed a whole tin). So hopefully that is all that was needed. I was told I can drive the car as there were no errors that were coming up.
On Monday I am taking the car to a certified Benz mechanic and have them run the test again just to be safe.
And for other members who are looking I found the below blog which is very comprehensive on ABC issues:
http://mercedes-abc-drive-carefully....rt-of.html?m=1
Old Feb 16, 2020 | 12:52 PM
sivikvtec's Avatar
2005 SL65 AMG
I would be very worried that either
1) your mechanic did not know how to properly check the fluid level and the system is now overfilled
2) You have a leak, which could be a hose about to explode while driving or a failing strut.
I’m also amazed (and somewhat doubtful) your mechanic had the correct fluid on hand.
Old Feb 16, 2020 | 02:20 PM
Dudeman's Avatar
Current: '07 SL550 & '14 GLK350. Previously owned: '06 ML350, '05 SL500, '99 ML320 & '98 SLK230 (RI
Simple enough to tell. How much did the mechanic charge for the one quart/liter of fluid? and did you see it, was it green. Did it say Pentosin, or CHF 11S on the bottle
Old Feb 16, 2020 | 04:49 PM
alexisvx's Avatar
2009 SL550
It was a CHF 11S. The Mechanic specializes in Mercedes and BMW's service and online reviews were really good from people with Mercedes.
Having said that, when I went to drive the car in the evening I got an Battery/Alternator Stop car warning! I am thinking that maybe something went loose when he did the rodeo test.
I have an appointment with the certified Mercedes mechanic tomorrow morning. Do you think it's safe for me to drive to them or should I have it towed (assuming the car can start)? I read that the breaks might not work with that warning.
I also wanted to take the opportunity to thank all the members for their advise. I'm new here having just gotten the car and I've posted a few times already. I really appreciate the insights and feeling welcomed. It's a bit daunting driving a new car for a few days and to keep getting hit by all these error messages.
Old Feb 16, 2020 | 10:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you needed fluid added, then you have a leak. The ABC system does not "consume" fluid. A very common problem on the MY2007+ ABC system is that the main pressure hose ll leak. It happens in the rubber hose section where it sits against the radiator, in front of the ABC/PS pump.
Old Feb 17, 2020 | 10:38 AM
thias's Avatar
SL 500 r230
When the accumulators fail, they fill up with hydraulic fluid, replacing the gas that is normally in them. So the "missing" fluid would also be a pointer to dead accumulators. As long as there is no puddle unter the car.
Old Mar 31, 2020 | 04:08 PM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
no need take it back, low level was the issue. add a bottle lqseal to take care of your system ,keep orings fresh and rubber in rest system healty.
Old Apr 7, 2020 | 02:16 PM
j4bs998's Avatar
SL500 2003
Similar problem
I have a similar issue, but I have never gotten an alarm. The back end is sagging and the ride was rough (brief as it was). The reservoir is empty, but I never saw a leak. Any chance the accumulators have broken and need replaced? Still worried that I never got an alarm though. Has anyone seen this?
Old Apr 7, 2020 | 03:28 PM
seven_out's Avatar
SL500, Miata
The accumulators may in fact be broken. One way to tell is to fill up the ABC reservoir to the higher mark on the dipstick, start the engine, and check the oil level again. If all accumalators are functioning, the level will have dropped to the lower mark.
Old Apr 8, 2020 | 07:32 AM
j4bs998's Avatar
SL500 2003
Thanks, I'll do this soon and let you know.
Old Apr 14, 2020 | 09:33 AM
ASAP you need add one bottle of this, after 4 days, your problems gone . Ebay you can get it .will restore all the acumulators o rings in 4 days, and also struits . will keep system good for 7 years.
Multi-System Sealer
PART NO. FT40204
Full Throttle® Multi-System Sealer restores hardened, shrunken and brittle seals. Specifically designed to soften and gently swell the seal, recovering its elasticity before it breaks.
  • For Use in Oil System, Transmission and Power Steering
  • Full synthetic, Solvent-Free Oil-Based Formula
  • Restores Seals and O-rings
  • Metal and Chlorine free
  • Concentrated Treatment
  • Stops Leaks
