SL/R230: SL55 supercharger pulley wear
With the belt on, everything seems fine, with normal clutch gap and no noise/play in the bearing. The car drives fine with normal supercharger engagement. However, with the belt off, the pulley wobbles around (probably around 1mm play) and the bearing freely spins in the pulley... I'm not talking about the bearing race rotating in the bearing housing, I'm talking about the entire bearing assembly spinning in the pulley.
I've taken the pulley off and removed the bearing. There's no play in the bearing and the OD of the bearing assembly measures 75mm, which is identical to a new bearing I have sitting around that I ordered a while ago. There are some wear marks on the bearing housing and some corresponding wear marks on the pulley.
Has anyone seen this before? It looks like the bearing has spun in the pulley, causing the pulley to wear. Obviously, the aluminium of the pulley is softer than the steel bearing. What I don't understand is how this could happen? Perhaps, under boost, the bearing housing starts to spin in the pulley?
There is a lot of force being applied to that pulley when engaged, so it doesn't surprise me. Belt slip is common at this pulley.
My only suggestion is locktight when installing the bearing and see how it goes. Worst case, you have to replace the whole setup.
Just ordered some Loctite 638 retaining compound, which I'll use on reassembly. Fingers-crossed, that will do the trick.
