SL/R230: Parking assist center recessed
Old Apr 18, 2020 | 06:39 PM
alexisvx's Avatar
2009 SL550
Parking assist sensor recessed in bumper
Hi all,
Those living in LA will be familiar with the numerous potholes all over the city. The other day I went through a massive pothole which shook the car quite a bit. The result was that the rear right parking sensor got dislodged and moved inside the bumper. Every time I put the car in reverse I can hear the proximity sensor.
Am I correct in thinking that I need to remove the bumper to fix this? It looks like a very long job. I found the below video. Is that the correct way for a 2009 SL550 or is there a simpler way to remove the rear bumper?
Old Apr 19, 2020 | 04:27 AM
pmercury's Avatar
member
CL
here you go
File Type: pdf
Old Apr 19, 2020 | 05:57 AM
Ivan750's Avatar
Mercedes SL r230
Hello, I had the same problem and I followed the steps of the video of youtube to disassemble the bumper. I advise you to put a little hot silicone in the area inside the sensor so that it does not happen again
Old Apr 19, 2020 | 09:03 PM
alexisvx's Avatar
2009 SL550
Originally Posted by pmercury
here you go
Thank you!
Old Apr 19, 2020 | 09:35 PM
alexisvx's Avatar
2009 SL550
Thank you. You followed the instructions of the video I posted above or a better one?
I Don't have hot silicone, anything else I can use?
Old Apr 20, 2020 | 03:02 AM
Ivan750's Avatar
Mercedes SL r230
Hello, I followed the instructions of the video that you have put. Disassemble slowly and without haste, it is easy but you have to disassemble carefully so as not to break anything
Old Apr 21, 2020 | 12:22 AM
alexisvx's Avatar
2009 SL550
Thank you.
