SL/R230: radio upgrade no audio
While going over everything realized I had the wrong adapter (for 2007 & up) I and am now using the FOBB01 most adapter, still not getting any sound and no blinking red light from any of the fiber optic connectors. Replaced that with another FOBB01 adapter thinking the 1st one was bad but same thing with this one. My next step is to ditch the fiber optics all together but really don't want to go that far. Hoping someone hear may have some suggestions on what could be my problem?
While going over everything realized I had the wrong adapter (for 2007 & up) I and am now using the FOBB01 most adapter, still not getting any sound and no blinking red light from any of the fiber optic connectors. Replaced that with another FOBB01 adapter thinking the 1st one was bad but same thing with this one. My next step is to ditch the fiber optics all together but really don't want to go that far. Hoping someone hear may have some suggestions on what could be my problem?here is the fiber diagram
as you see they go in and out from one module to another
if one of them was removed or not letting thru the signal to the amp you have a problem
other problem is that you have to make sure the amp is turning on with the radio
I remember removing the in to first in line (if I remember well) and route it direct to amp
you can remove cd charger, sat, and all now unusable units in the fiber circuit as not activated and working anymore
If you have Xentry, or a tool to edit Central Gateway module and cluster. devices should be removed there to for perfection
If you don't I don't think it will trigger anything and its fine to drive with errors in your system
sure someone else knows better as I have done this years ago. but at least you have a idea of how all this works
good luck
it must work without
also running new fiber is not necessary
just take the in to first device in the line and hook it up direct to amp. I needed no extra fiber
not 100% sure but in my case it was the cd charger not letting the signal thru
the wire that triggers the amp should be on your Xtrons adapter
you can verify easy direct on the amp with a voltmeter if it turns on or not
, shut it off and haven't been able to get it to come on again? thinking maybe I have an issue with the gateway? I've swapped everything else out with no luck, I'll have to start looking for one.. Otherwise I'll have to try a 3rd adapter I'm determined to figure this out!
, shut it off and haven't been able to get it to come on again? thinking maybe I have an issue with the gateway? I've swapped everything else out with no luck, I'll have to start looking for one.. Otherwise I'll have to try a 3rd adapter I'm determined to figure this out!100% sure not the gateway
probably the fiber or amp on trigger wire
