SL/R230: Spark plugs change for novice
Old May 12, 2020 | 09:37 PM
alexisvx's Avatar
2009 SL550
Hi,
I recently got a 2009 SL550 and for the first time ever, I really want to take care of my car. With advise from this forum, I recently changed the roof hydraulic pump myself (Tophydraulics fixed the burned motor), I just did a power steering flush and next intend to do a break fluid flush, a cooling system flush, ABC flush and change the fan belt, none of which I have never done before.
The advice I wanted from you all is how easy and how 'dangerous' is it for a total novice to change the spark plugs? I have seen multiple videos and have read about it and think I get the theoretical aspects of it. But what are the consequences of making a mistake? Should I get more experience before I attempt the spark plugs change?
Old May 12, 2020 | 10:26 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Do the valve cover gaskets while you’re at it!
make sure to torque the plugs to spec and be careful with over tightening any of the bolts for the gaskets as well.
not that difficult of a job just time consuming if they are old and original.
Old May 13, 2020 | 08:37 AM
onewhippedpuppy's Avatar
Plays With Cars
It's an easy project, especially on these cars. Make sure you have a thin wall socket, I was able to use a 3/8 drive deep socket that fit, but my 1/2 drive was too fat to fit into the hole in the head.
Old May 15, 2020 | 03:13 AM
Rawhide's Avatar
2003 SL55, 2004 E320 CDI Estate
Best tip I learned was to turn it backwards until it drops into the thread to avoid cross threading. Ive not had to do this job yet though.
Old May 18, 2020 | 08:23 AM
Plays With Cars
No matter the car, I always hand thread in spark plugs to avoid cross threading. If it quickly gets tight, back it off and try again.
