SL/R230: Engine Type ?? HELP !!
Old May 27, 2020 | 01:23 PM
oakcreekeric's Avatar
2003 SL500
Hello All -
I was looking on Ebay for some engine mounts and I noticed it gives two options for engine type -
5.0L 4966CC V8 GAS SOHC NATURALLY ASPIRATED
or
5.0L 4973CC V8 GAS SOHC NATURALLY ASPIRATED
How do I tell which one I have - I ask, because as I mentioned, I was looking for some engine mounts and the 4973CC gives me the option to purchase the FEBI Bilstein mount (https://www.ebay.com/itm/Engine-Moun...0AAOSwDZ1bJDEG) and the 4966CC only allows me to buy the Lemforder one
I'm not sure which one is best - if there is a major difference - but I would like to make sure I purchase the correct/best one
My VIN # is WDBSK75F23F028293 - I did the VIN decoder and it didn't say which engine I have
Can anyone help me ?
Thanks in advance for the help !!
Old May 27, 2020 | 04:56 PM
imtheking's Avatar
Former R230, W220 and W221 owner
I believe Lemforder is the OEM- you want to stick with genuine motor mounts- no exceptions
Old May 27, 2020 | 04:58 PM
pmercury's Avatar
member
CL
Originally Posted by oakcreekeric
Hello All -
or
here is your OEM part number based on your vin
A2302400017
Old May 27, 2020 | 05:00 PM
imtheking's Avatar
and a few links to help
https://www.autohausaz.com/pn/OE-2302400017
https://www.fcpeuro.com/products/mer...500-2302400017
Old May 27, 2020 | 05:05 PM
pmercury's Avatar
member
CL
Hello All -
or
and here is your epc basic datacard
File Type: pdf
Old May 28, 2020 | 08:55 AM
2003 SL500
Thank you Thank you - for the quick responses - and THANK YOU to @pmercury for the datacard - I very much appreciate that
However, the questions remains, which engine do I have ?
I reviewed the datacard and the VIN decoder - either I'm completely blind and missing it, or its not on there - Does anyone know ???
Old May 28, 2020 | 09:03 AM
pmercury's Avatar
member
CL
113963 engineEngine capacity4,966 cc
113.963 => M 113 E50
Old May 28, 2020 | 09:34 AM
2003 SL500
Thanks @pmercury I appreciate the information.
Just to be curious - do you have any background information on the 4966cc vs 4973cc engine - obviously the 4973cc engine is slightly bigger - was the change a year thing, or was it a running line change and the VIN number is the only way to determine which engine you have?
Also, where would I have found this information - I didn't see it by looking at your datacard or the VIN decoder - just trying to educate myself and understand where/how you got the information
Thank you again for your help !!
Old May 28, 2020 | 12:27 PM
pmercury's Avatar
member
CL
never searched I am only in V12's
look at the datacard, engine number is there
take the first part and google
Old Aug 25, 2022 | 12:31 PM
XCAXSA!NT's Avatar
Acar
Type in your vin at vindecoderz and it will tell you under the build sheet if you either have an M113 (4966cc) which are in 2000 and up Or M119 (4973cc) which are prior to 2000.
www.vindecoderz.com
https://en.wikipedia.org/wiki/Mercedes-Benz_M113_engine
https://en.wikipedia.org/wiki/Mercedes-Benz_M119_engine
