SL/R230: Door buzzer
Old Jun 28, 2020 | 01:20 PM
NHSl550's Avatar
2007 SL65, 2009 SL550, 1991 SL500
Door buzzer
Anyway of turning off that annoying door beeper that comes on when You open the driver door 07 SL65
My 09 SL550 doesn't do that.
Old Jun 28, 2020 | 01:31 PM
pmercury's Avatar
member
CL
You mean the "you forgot your key" buzzer
maybe in vediamo but it would be a big exploration for something not many want to remove
Old Jun 28, 2020 | 01:57 PM
NHSl550's Avatar
Ya that's the one. Annoying as hell.
Old Jun 29, 2020 | 06:24 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Agreed, VERY annoying. There are posts in this and other forums about this annoying chime. You will find workarounds and a bit about owners who have disassembled the cluster and cut wires to the chimer. Later command versions like my 2012 w220 have pleasantly only 1 chime an message on IC. If only that software would work on older command versions. Get to work pmercury you would be a hero..
Old Jun 30, 2020 | 02:43 AM
pmercury's Avatar
member
CL
ok ok got it give me a day
Old Jun 30, 2020 | 03:16 AM
pmercury's Avatar
member
CL
ok think I found where to change it, just ring me I'll test it
Old Aug 26, 2020 | 04:10 PM
NHSl550's Avatar
Hi Peter. Were you able to find anything on this?
Old Aug 26, 2020 | 04:24 PM
pmercury's Avatar
member
CL
Ill have to connect to the car with vediamo
whatsapp me when you want
Old Aug 26, 2020 | 07:22 PM
NHSl550's Avatar
What would be a good time tomorrow?
Old Aug 27, 2020 | 02:31 AM
pmercury's Avatar
member
CL
sure
always there
Old Aug 30, 2020 | 04:43 PM
SaLambert's Avatar
2007 550sl
Come on pmercury, you’re not going to share your findings with group? Ive had my ‘07 sl550 for a month and that sound kills me.
Old Aug 30, 2020 | 05:21 PM
pmercury's Avatar
member
CL
of course I will once I found it.
but it won't help you as this is hex code and vediamo, not Xentry
but i'll let you know if its possible
Old Apr 28, 2022 | 05:05 PM
NHSl550's Avatar
Did anyone ever find a way to do this?
Old Apr 29, 2025 | 01:10 PM
NHSl550's Avatar
I'm bringing this back. Anyone ever figure this out?
Old Apr 30, 2025 | 08:49 AM
W205C43PFL's Avatar
Message the coders now directly, maybe they have a solution. Otherwise, unplug the speaker responsible for this but then you disable other sounds like turn signal, warning chimes.
Old Apr 30, 2025 | 10:09 AM
aegea's Avatar
2004 SL500AMG, 2003 SL500 USA
Please let me know if this works for you.
I used a Mercedes proprietary scanner system that uses a multiplexor and personal computer. Menu structures are based on this system in most newer scanners. Using a system within STAR Diagnostics is a system called DAS.
TO STOP ANNOYING CHIME and BATTERY DRAIN, I think: (See the following post in this thread for DAS screen shot. (8) Annoying "Dont Forget Key Chime" | Page 2 | Mercedes-Benz Forum)
In DAS under Control Units, Information and Communication, Instrument Cluster with Maintenance…(ICM), Control Unit Adaptations, when asked toggle on your model year, hit F3, Special Equipment, I toggled Keyless Go to NOT PRESENT, pressed F3 function key twice, then pressed F5 to send code to the control unit. "Don't forget the key" warning in the dash is now gone. Because someone warned us in this thread, I did not toggle menu item “key dependency” to not present.
Because I could not get Keyless Go to work and the chime to cease when I was closing the door, I de-soldered the chime connection behind the instrument cluster long ago. I think making Keyless Go NOT PRESENT would have stopped the terrible chiming. I think this will stop the battery drain too.
