SL/R230: Newbie needs help with manual top
Old Jul 12, 2020 | 06:24 PM
macdoesit's Avatar
sl500
1999 SL500----Hydraulic fluid sprayed straight up in the air on rear passenger side needTo manually put on hard top, I found the levers but the one on driver side in back is in the lock position and moving the lever does not move the lock to the open position, the prong on the hardtop cannot go down and latch. Can anyone help.
Old Jul 13, 2020 | 05:55 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by macdoesit
I found the levers but the one on driver side in back is in the lock position and moving the lever does not move the lock to the open position...
You can purchase a replacement lock mechanism for not much money from eBay. Meanwhile, you could unscrew the prong from the hard top so that you can mount it.
Old Jul 13, 2020 | 06:34 AM
macdoesit's Avatar
sl500
How can I get the lock mechanism in the unlock position, everything was working great till the hydraulic leak.
Old Jul 13, 2020 | 10:33 AM
bobterry99's Avatar
With the lock assembly removed you ought to be able to figure how to get it to open. However, since the lever seems not to work I don't see how you will be able to lock it.
Another option is to send the leaking cylinder to TopHydaulics.com for repair.
Old Jul 13, 2020 | 12:29 PM
macdoesit's Avatar
sl500
I watched his videos and recommended new cylinders.
Question, in order to lock the back of the hard top , do you just push down on the corner of the hard top.
