SL/R230: Plz Help - 2008 SL550 won’t crank... now no “Key On” Or windows....
I took a deposit on it to sell the car when I was laid off back in May. They were on the way to pick it up and I was cleaning it up a bit when the check engine light came on. It was the code for the electric air/smog pump.
I pulled the relay, cleaned and replaced like I did a year ago when it had the same issue (which fixed it until now), and the car hasn’t started since.
The starter relay is behind the air pump relay on the passenger side under hood box, so I removed, cleaned and replaced it as well but no luck.
I tried a different fresh starter battery today, probed around a little, and now the driver side windows won’t roll up or down.
I’m leaning towards it being an ignition switch, but had a falling out with the friend with a SDS.
All head/tail lights work, horn and stereo work but the dash doesn’t activate when the key is turned to the “on” position and AC doesn’t power up.
Ive tried locking and unlocking - trunk opens and closes as it should.
Any specific fuses/relays or switches I can test without SDS?
I have worked through some of these issues before.
