SL/R230: 2006 sl65.
Old Oct 7, 2020 | 02:27 PM
Rad Aba's Avatar
2006 mercedes benz sl65 amg
2006 sl65.
i got white smoke on start that smells like burning gas.. check engines light goes on every time i fill up (cap is new)
changed coils. plugs. all air sensors. catalyst air sensors. HELP ME... mercedes can't figure it out either
Old Oct 8, 2020 | 08:09 AM
pmercury's Avatar
member
CL
you can't repair things like that without diagnostic software
did MB print you out the diagnostic ?
Old Oct 8, 2020 | 12:08 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I think reading that diagnostic code is a logical starting point. Typically auto part stores will read OBD-II "check engine" codes for free. Then I'd be looking at short and long term fuel trims with an advanced OBD-II code reader or Star Diagnosis clone.
Old Oct 8, 2020 | 12:50 PM
chassis's Avatar
2017 GLE350 4MATIC
Read codes.
white smoke that smells like gas is unburned gas. Fuel delivery and injection system must be working. Ignition and combustion system isn’t working. Coils wires and plugs plus whatever drives them.
what about the evap system?
Old Oct 9, 2020 | 07:38 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Please get a proper diagnosis using MBStar das. Whomever you call Mercedes should have provided a fault code list and diagnostic fix. Did you receive this? Perhaps you received a throw parts and labor fix until it stops. You own a very sophisticated mobile area network of sensors controlled by computers and software. Sl65 in your case even more sophistication. It takes sophisticated diagnostic work on these cars. In my case I do that before the wallet opens and repair order issued. Take it back to who ever did the work and ask to get a thorough free diagnostic and report fault codes and what ever else would help the forum help you. Keep us posted.
