SL/R230: R230 SOS "Call Connecting" issue
Old Oct 12, 2020 | 03:36 PM
buckize22's Avatar
SL500
I have a 2003 R230. I have a battery drain issue that I am sure is related to the SOS system that I attempted to deactivate. I removed related fuses, only to cause another issue after those fuses were returned!
Within a minute or two of new start, the SOS system tries to compete a call on a phone that does not exist. It has been an annoyance by itself, but the overriding issue is that it drains the rear battery very quickly and renders the entire electrical consumers system weak...
How can I deactivate this system properly?
Thank you for in advance for any assistance.
Old Oct 13, 2020 | 12:46 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
I do not own a a SL, but my guess would be to check the manual or call MB themselves!
Please contact our Customer Assistance Center at 1-800-FOR-MERCEDES (1-800-367-6372), or send correspondence to: Mercedes-Benz USA, LLC Customer Assistance Center 3 Mercedes Drive Montvale, NJ 07645
Remember they work for you!
R
2MERKS
Old Oct 13, 2020 | 04:58 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I removed related fuses...
I'm guessing you only needed to remove one fuse: Fuse 76 in the rear fuse box which supplied power to the TELEAID module. If that doesn't work, Mercedes' Star Diagnosis System (SDS) can deactivate TELEAID through a setting in the instrument cluster configuration. A well-equipped independent shop might do it for a fraction of their hourly rate. Better still would be to purchase an SDS of your own. A clone can be had for as little as $250, but it would likely take 2-3 weeks to be delivered to you.
Old Oct 13, 2020 | 11:08 AM
buckize22's Avatar
SL500
Thank you for the 411... I appreciate it.
