SL/R230: TCM not reading
But I would start looking at your SBC and see if it's OK, then the ABS and ESP and so on. When your SBC approaches it's End of Life (as calculated internally), it starts giving errors such as you see, then eventually shuts down or fails altogether.
1) check fuse 37
2) check for power across pins 4 & 5 at the transmission connector (red/black and brown wires)
3) check for continuity on CAN wiring and check condition of connection at terminal block
Mike
1) check fuse 37
Mike
Why would the TCM give out ABC, Distronic and ESP errors. Those errors and the car being forced into LIMP mode would indicate a problem in the braking systems, most likely SBC.
I'm chiming in because I have a similar issue. I have a 2009 R230 and the ABS ESP message, my car will not shift into gear, and my iCarSoft shows TCM not communicating/ the U0101 error code. I've tried getting to the TCM but on this face lifted version there are no pics, instructions, or diagrams to show where it is. I can't figure if it is the 722.9 gearbox TCM conductor plate that is in the transmission housing, or the A0275450332 part that is supposed to be located in the passenger side footwell. I opened up the footwell area and I didn't see a TCM on the side, or on the backside of the metal plate. Only thing behind it was the Harmon Kardon Subwoofer. If anyone knows where I can find the TCM proper on an 09 SL 550 I would really be grateful. I will take it into the dealer if all else fails.
Hi Carlos, I’m also having the same issue and it’s frustrating any luck solving it?
1) check fuse 37
Mike
