SL/R230: Things to look out for on a used SL 500
Is there anything that I should look out for. This car is at a Mercedes dealership and their described "checklist" seems pretty thorough. I noticed some rust on some pulleys in the engine, but it's surface rust that I could treat. Interior looks incredible, exterior is 9.5/10. Carfax looks good. What should I dig deeper on? Is there anything I should be concerned about if I did purchase? It has 92k on the odometer. I am aware of the active suspension concerns.
Thanks for any and all replies.
At lot of what I listed above isn't necessarily expensive to fix, but they are common problems and will help in your negotiations. I'm sure I missed a few things and others will probably chime it to add to the list.
There is more than one way to negotiate. If there is uneven wear on the tires, for example, demand a suspension check, alignment, and maybe new tires. Ask them if it has the new 3 micron filter for the ABC. If they can't tell you yes, have them replace it. Ask for a transmission fluid/filter service. Also, another good technique is to walk away and tell them to call you if the price drops again.
They will probably claim that 92k is low mileage and it really is for a 16 year old car. However, the SL's didn't get driven heavily and 92k is probably a little above average for an '04. I wouldn't be scared off by it, but it does affect the value and is a point of negotiation.
Hello, I bought a 2003 with 23.5k miles, original owner, stored in an airconditioned garage and it had a brand new appearance and ride. I couldn't resist this beauty, so I bought it. The trouble I experienced was electro mechanical- the hardtop convertible failed on 2 or 3 separate occaisons and was resolved by a local non Mercedes shop for just under $1500.00 ouch. When you buy a car this old, it has 2 things going against it: One is age and the other is mileage. In my case , aged manifold seals are causing check engine light to come on. These (there are several) will be replaced until the light is extinguished. Hardtop convertible actuators, hydraulic fluid pumps that activate the hardtop can cost you thousands to fix. Engine and transmission are flawless though and the ride is superb. On another note , the car has a sophisticated electro mechanical front seat controls that are supposed to massage your back while you drive-very nice if they worked but unfortunately this is a major flaw in this vehicle. from what I read, most of these older models have failure in this system. Very expensive to fix too. Just be aware that you can expect some what could be hefty repair bills. My advice is to get all the service records and check them thoroughly.
