SL/R230: awful tires
285/30ZR-19 CONTINENTAL EXTREMECONTACT DWS 06 XL
and they are terrible. I get the flashing yellow traction control light often and I'm not that aggressive of a driver. It's not a throttle control thing as it often happens when I'm just coasting through a curve. I can't believe these tires are so much worse than the
285/30ZR-19 CONTINENTAL EXTREMECONTACT DW XL
that I had previously. I live in Texas and don't need an all season tire. As soon as the fronts are worn out I'll replace all 4 with Michelin Pilot Sport 4S's if I can find them in my size.
https://www.tirerack.com/tires/tires...s+V12+evo+K110
Currently working through a set of DWS 06s (PO had them installed right before I purchased the car).
While I wouldn't buy them for a 3-season sports car, I have to admit that they have done a surprisingly good job on my SL...even when pushed.
FYI, the Pilot Sport 4S is yet to be offered in a 285/30ZR19 size. You'll need its predecessor for that size, the Pilot Super Sport. Excellent tire.
I've had problems finding Michelin's in my size and that's disappointing that the 4S is not offered yet in 285/30ZR19. I have the previous versions in whatever size the front it. I wonder if the mismatch between the tires is contributing to this? They are down to 4/32" so I'm going to replace them soon and will do a full set of the same tires. Making arrangements with kbob999 to send him the all-season rears.
What size are the fronts? Can you engage the cruise control at 55 mph, and it stays on?
Not having cruise working is the first sign of tire mismatch.
The fronts are 255/35ZR-19 MICHELIN PILOT SUPER SPORT XL. Cruise control and normal driving are fine but even mildly spirited driving results in automatic braking and the stability control light blinking.
There may be more to the problem than the tires.
Test the tires at 35 PSI front and rear and see what happens. Otherwise, a scan with the SDS may uncover other issues.
2009 SL550
2009 SL63
I run +2 PSI over factory, so 38 PSI front, 40 PSI rear. Continentals have relatively softer sidewalls, which don't respond well to lower tire pressures.
Worth a shot.
My 2003 SL55 used 18" stock wheels, and the door card shows 35 front / 36 rear for tire pressures. That is what I run on my 19" tires.
See attached picture: recommended tire pressure 26 front / 29 rear. You would think MB would make a standard among same class vehicle
But for me i would not go higher than 32, because when the tires get hotter, especially in summer, the ride quality gets worse exponentially...
I do think there may be more going on than just the tires for stability control issue. I asked the tire shop about this and they had a few people drive my car were able reproduce it but they didn't think anything was wrong with the car. This isn't my regular shop.
Would an SDS store the reasons for why the stability control was activated after the fact? I live alone and can't be watching it while driving.
If there is an error in the system that is current, it responds with "F" for the fault.
If it happened in the past, but is not happening now, it shows "f" for the fault.
As you suggest, I don't think a 'normal' track day stability response would be recorded in the system.
2009 SL550
2009 SL63
Worth a shot.
EDIT .... I just checked and the 2009 SL63 appears to only weigh 44 more pounds than a 2009 SL550 ... so that is NOT the explanation (my bad : ) (I seemed to recall that the difference was a lot greater between the AMG and non (steel vs alum sub-frame ... bigger brakes, etc), but that must not apply to 2009 ...
For the nose-heavier SL65, factory spec is +2 PSI Front / +3 PSI Rear over the SL63. The recommended pressures for the SL550 are too low, IMO. Regardless of which iteration, this is a heavy car with an aggressive wheel/tire setup.
Continental tires, in my experience, have softer sidewalls. Meaning, tires pressures that work well with a Michelin or Pirelli tire can be too low for a Continental. Experienced this on several BMW and Audi cars over the years with the DWS 06 specifically, where bumping up the PSI moderately corrected any ride issues.
2009 SL65:
will try replacing the rears. tire rack shows:
https://www.tirerack.com/tires/TireS...&affiliate=KE2
for 285/30ZR19 rears. think I'll go for the Michelin Pilot Super Sports. anything but the Continental DWS 06.
But I will wait for when the fronts are ready to be replaced (which should be within the next few months) and when I get codes scanned with a proper scanner to make sure there isn't something else off.
was due for B-service so I asked them to scan for faults relating to traction control. Paid extra $135 for:
"Fault in the tele aid for large deviation between wheel speed signal and speed computed based on GPS signal. Check wheel speed. No issues found, all speeds reading. Check tele aid, it is operating okay. clear all fault codes. Correct tire pressures and test drive, traction control working okay."
After I picked up the car I was able to trip the traction control on a mild curve that didn't trip it before these tires.
When the fronts need replacing (which will be soon since they are at 4/32") I'll replace the rears too. Will update this post at that time.
